Canon PIXMA MP130 All-In-One InkJet Printer Logo
Posted on Nov 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon Pixma MP 110 Model Display sign comes on "Waste Ink Absorber Full" and printer won't work.
  • Anonymous Nov 18, 2008
    Display sign comes on with Waste Ink Absorber Full, and it won't work.
  • ysaneyoshi May 11, 2010
    Does this come on before you run a print command (does it show up when you turn on the printer), or after you've sent it a print request?
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Feb 08, 2010
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1813572
Points
14613
Hi There this is old posting but you may call back
How To Reset Waste Ink Canon Pixma MP130
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
When I switch on my Canon Pixma MP 160 Printerr, the display flashes "E8" Error message. Please give me a simple solution step-by-step to solve this problem
Welcome to Fixya
E8 = Waste ink absorber full or platen waste ink absorber full. The first thing you need to do is Press or button to clear the error and continue printing. If still the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the button again.
  3. Wait until the device has completed its cycling process before submitting another job request
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Pixma MP 130/110 Printer/Copier/Scanner waste ink absorber full, It neither prints nor copies
Cleaning the waste ink pads is easy.
Are your ink tanks empty and have you been using non Canon cartridges?
Regards,
Worldvet
I have a Canon Pixma MP 130/110 Printer. Machine is not printing. Have been through all the recommended cleaning/ maintenance procedures several times and fitted new ink cartridges all to no avail. Message...
Pixma IP3000
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
1helpful
HOW DO I REPLACE MY CANON PIXMA MP 110 WASTE INK THANKS VERY MUCH
Replacing is not the only problem, Canon didn't make any parts available for that machine and there's no way to reset the error code.
27helpful
2answers
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
1helpful
My Canon Pixma MP 170 tells methe waste ink absorber is full...
It is a shop repair since you have to use Canon diagnostics to reset the count and clear the error. The new part is around $10.00 only.
Cartridge jammed / Waste Ink absorber almost full
Waste ink pad or pads are full and need changing.
Under your ink carraige cradle it is,
It will be full, bit of a dirty job.
Hope this helps
Ric.
5helpful
2answers
Printers Problem Canon MP 145 code E27
Try this fix.....CLICK HERE
It works the same for the Canon MP 150 or MP 160
3helpful
Waste ink absorber is almost full
Try this:
Resetting overflow error code for Printer Canon Pixma MP110
  1. Turn on the printer.
  2. Click Menu, and then Scan, Copy and Scan again. All - entered the service mode.
  3. Select Counter
  4. Click Copy - everything. Waste dropped to zero.
  5. Turn off the printer POWER button.
Good luck
old marine
old marine
ZJ Limited
ZJ Limited
