Question about VIA P4MA Motherboard
Increasing memory beyond 512meg
I cant increase my memory beyond 512 Megs
    Genius:
  • 1,605 Answers
Did you get the right memories???
DDR266, SDRAM???
basically the memories is PC2100, 266Mhz
ya! 2Gb max out.
check your BIOS
Posted on Nov 06, 2008
When increase the memory card 2gb to 4gb using drive increaser but while formating it while showing only 2gb why?
Older systems, only can format 2 Gbyte in FAT-16. In 10 years, we grew from 512 Mbyte cards to 512 Gbyte for cards. The systems sold in this time, did not change. After SD, came SDHC and since 4 years we have SDXC (above 32 Gbyte)
When you are lucky, you can use a card with more capacity, but your device will not be capable to use more that the 2 Gbyte it was build for.
Feb 03, 2015 | Electronics - Others
Tip
MAKE " WINDOWS XP " GO FASTER
Services You Can Disable
There are quite a few services you can disable from starting automatically.
This would be to speed up your boot time and free resources.
They are only suggestions so I suggestion you read the description of each one when you run Services
and that you turn them off one at a time.
Some possibilities are:
Alerter
Application Management
Clipbook
Fast UserSwitching
Human Interface Devices
Indexing Service
Messenger
Net Logon
NetMeeting
QOS RSVP
Remote Desktop Help Session Manager
Remote Registry
Routing & Remote Access
SSDP Discovery Service
Universal Plug and Play Device Host
Web Client
Cleaning the Prefetch Directory
WindowsXP has a new feature called Prefetch. This keeps a shortcut to recently used programs.
However it can fill up with old and obsolete programs.
To clean this periodically go to:
Star / Run / Prefetch
Press Ctrl-A to highlight all the shorcuts
Delete them
Not Displaying Logon, Logoff, Startup and Shutdown Status Messages
To turn these off:
Start Regedit
Go to HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionpoliciessystem
If it is not already there, create a DWORD value named DisableStatusMessages
Give it a value of 1
Clearing the Page File on Shutdown
Click on the Start button
Go to the Control Panel
Administrative Tools
Local Security Policy
Local Policies
Click on Security Options
Right hand menu - right click on "Shutdown: Clear Virtual Memory Pagefile"
Select "Enable"
Reboot
For regedit users.....
If you want to clear the page file on each shutdown:
Start Regedit
Go to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory ManagementClearPageFileAtShutdown
Set the value to 1
No GUI Boot
If you don't need to see the XP boot logo,
Run MSCONFIG
Click on the BOOT.INI tab
Check the box for /NOGUIBOOT
Speeding the Startup of Some CD Burner Programs
If you use program other than the native WindowsXP CD Burner software,
you might be able to increase the speed that it loads.
Go to Control Panel / Administrative Tools / Services
Double-click on IMAPI CD-Burning COM Service
For the Startup Type, select Disabled
Click on the OK button and then close the Services window
If you dont You should notice
Getting Rid of Unread Email Messages
To remove the Unread Email message by user's login names:
Start Regedit
For a single user: Go to HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionUnreadMail
For all users: Go to HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionUnreadMail
Create a DWORD key called MessageExpiryDays
Give it a value of 0
Decreasing Boot Time
Microsoft has made available a program to analyze and decrease the time it takes to boot to WindowsXP
The program is called BootVis
Uncompress the file.
Run BOOTVIS.EXE
For a starting point, run Trace / Next Boot + Driver Delays
This will reboot your computer and provide a benchmark
After the reboot, BootVis will take a minute or two to show graphs of your system startup.
Note how much time it takes for your system to load (click on the red vertical line)
Then run Trace / Optimize System
Re-Run the Next Boot + Drive Delays
Note how much the time has decreased
Mine went from approximately 33 to 25 seconds.
Increasing Graphics Performance
By default, WindowsXP turns on a lot of shadows, fades, slides etc to menu items.
Most simply slow down their display.
To turn these off selectively:
Right click on the My Computer icon
Select Properties
Click on the Advanced tab
Under Performance, click on the Settings button
To turn them all of, select Adjust for best performance
My preference is to leave them all off except for Show shadows under mouse pointer and Show window contents while dragging
Increasing System Performance
If you have 512 megs or more of memory, you can increase system performance
by having the core system kept in memory.
Start Regedit
Go to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory ManagementDisablePagingExecutive
Set the value to be 1
Reboot the computer
Increasing File System Caching
To increase the amount of memory Windows will locked for I/O operations:
Start Regedit
Edit the key IoPageLockLimit
Resolving Inability to Add or Remove Programs
If a particular user cannot add or remove programs, there might be a simple registry edit neeed.
Go to HKCUSoftwareMicrosoftWindowsCurrentVersionPoliciesUninstall
Change the DWORD NoAddRemovePrograms to 0 disable it
4096 - 32megs of memory or less
8192 - 32+ megs of memory
16384 - 64+ megs of memory
32768 - 128+ megs of memory
65536 - 256+ megs of memory
on Jan 03, 2010 | Computers & Internet
Is there a way the memory in a toshiba satellite 1005-s157 be increased to more than 512MB?
Yes you can, at least to 1 Gb maybe possibly to 2 Gb.
There will be two memory slots in your laptop. To increase the RAM to 1 Gb install another 512 Mb RAM module in the empty 2nd memory slot. Make sure you use the same make and speed RAM as the one that is installed.
If you have two 256 Mb RAM modules installed in your laptop then you need to replace the two 256 Mb RAM modules with two 512 Mb RAM modules to get a total of 1 Gb RAM.
Aug 04, 2012 | Toshiba Computers & Internet
I have a G320 laptop with 512 SO-DIMM DDR400 and 1 GhZ procesor ,OS WIN XP, how can I run my G320 faster
There is nothing much that can be done to speed up the system as it can not go beyond 1GHz Processing speed, but several operating system tweaks and some hardware upgrade could make a little but notable difference.
As for Hardware, you may increase the RAM. You can upgrade memory on ECS Elitegroup Computer G320 upto a maximum of 1.0 GB (The ECS Elitegroup Computer G320 takes the PC2100 DDR SDRAM SODIMMs Memory)
Secondly, You may increase the size of PAGE FILE, uninstall unwanted software, Remove unwanted start-up items, Clean Junk Files/ Temporary files, De-fragment the Hard Disk to achieve the maximum speed and performance that EliteGroup G320 PC can give.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | EliteGroup G320 Notebook
I have a DELL with XP-Home Edition - version 2002 service pack 3, Intel(R) - Pentium(R) 4cpu 2.66ghz, 2.66ghz, 512 MB of RAM My daughter plays games and has 24 of them in the computer - she tells me I...
Hello, Jim.
Dell's official position is that the maximum memory for this PC is 1 GB. But, it may be able to support 2 GB, per Intel's specs.
But, to answer your question - yes - you can increase your memory amount to 1 GB. Since the system has 2 memory slots, you could conceivably have (2) 512KB modules (total 1 GB). If your system already has 1 module of 512 KB, you could add another. Just be certain it's the same type and speed.
Or, you could have a 1 GB module.
I don't think that your computer's life is in jeopardy, but additional memory always helps the speed of your computer.
Hope this helps.
Sep 19, 2010 | Dell Dimension 2400 PC Desktop
How can i increase my ram in intel desktop board 815
Hey,
Ram can not be increased as it is a hardware component in the computer, you can install more ram or upgrade the current ram modules that are inside the computer.
Feb 24, 2009 | Intel Motherboard
Upgrade the shared graphic memory
there should be a setting in the bios to adjust the shared memory with video.
Feb 02, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Purchased more memory from 256 to 512 the tech that installed the memory installed the 512mb DDR 2100 and left one of the 128 chips installed to give a total of 640mb ram receive error message "out...
Run Registry Editor (Regedt32.exe).
2. From the HKEY_LOCAL_MACHINE subtree, go to the following key: \System\CurrentControlSet\Control\Session Manager\SubSystems
3. Select the Windows value.
4. From the Edit menu, choose String.
5. Increase the SharedSection parameter.
For Windows NT:
SharedSection specifies the system and desktop heaps using the following format:
SharedSection=xxxx,yyyy
Add ",256" or ",512" after the yyyy number.
For Windows 2000, Windows XP, and Windows Server 2003:
SharedSection uses the following format to specify the system and desktop heaps:
SharedSection=xxxx,yyyy,zzz
Increase the zzz number to "256" or "512."
Best Of Luck!!
Jul 21, 2008 | Gateway Computers & Internet
Vista subcores
Try going into the BIOS of your laptop.
In the graphics are increase the memory allocation to the graphics card from 128 to 256.
If it already at256 increase to 512 etc.
please let me know if this resolves the issue.
Feb 26, 2008 | Toshiba Satellite A135 Notebook
Windows vista graphics subscore
VIA P4MA Motherboard Logo
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
