Question about Xerox WorkCentre M20i All-In-One Laser Printer
Paper feeder I have filled both paper trays but the green "no paper" comes on It is showing the flashing green light from the side
    President:
  • 2,072 Answers
One of two things, There is a black plastic actuator that may have fallen off. It hangs down into the paper tray and is pushed up when the paper tray is pushed in. Remove the paper tray and see if you can locate the actuator.
The more likely problem is the sensor in the paper feeder, I don't believe that sensor is a spared item, I have always replaced the paper feeder to resolve that problem.
Posted on Nov 07, 2008
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Red light flashing when printer turned on paper tray full
which printer is this?
make sure there are less number of papers in the paper tray.
try removing all the papers from the paper tray.
check for any obstructions in the paper feeder / printer.
Sep 22, 2009 | Office Equipment & Supplies
Paper out canon pixma ip200
Either you have selected the wrong feeder, it can feed from the back or the front tray, the little green light shows which tray is selected. If you have paper in both, the feed roller may need cleaning since it gives that error if paper doesn't get picked up.
Sep 01, 2009 | Canon PIXMA iP2000 InkJet Printer
Hi, While loading paper I'm getting an alarm saying E2 though papers are present in the paper tray. I 've pulled the clip in the paper feeder to the left, kept the paper i.e. alligned it to the right of...
Does your printer have a paper tray on the bottom as well? If so there's a feed switch that tells your machine to use the tray or the rear feeder. There's also a small printer picture with a light that either is lit for the top or bottom feeder. To be safe, put paper in both trays.
Aug 13, 2009 | Office Equipment & Supplies
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Loading paper from top.
there is a button to press to swap it from the back tray and the bottom tray. it sounds like you might have some thing stuck in the rear feeder causing the paper not to go through. i would try it from the bottom feeder and see if it works,
might be worth turning the machine off and unplug it and then try turning it upside down and shaking the machine, to see if anything come out of it.
If not i would say to take it apart or call a service engineer out.
Hope this helps
Oct 20, 2008 | Canon Pixma MP500 All-In-One InkJet...
No Paper Light wont go out
is this still a current issue?
Jul 22, 2008 | Brother MFC-8860DN Printer
Xerox WorkCentre M20i All-In-One Laser Printer Logo
65 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
