Question about Cameras
AF is not working
I use AF-S Micro Nikkor 105mm 1:2.8 G ED for Nikkon F5 camera but recently the AF is not working at all. I wonder if anyone knows how to fix the problem. Thank you and God bless.
    Guru:
  • Cameras Expert
  • 362 Answers
I would start to diagnosis the problem as follows: When the lens functions properly and is on the camera, the lens aperture is forced wide open by a pin on the camera body pushing a lever on the lens that opens the aperture. As part of the sequence when you push the shutter button, the camera releases its pressure on the spring-loaded lever on the lens, allowing the aperture to close to the setting that the "computer" has determined as correct. You will find this lever on the outside of the black ring that surrounds the rear lens element. With the lens removed, find the lever and make sure that with the lens set to the smallest f-stop (largest number such as f22), sliding the lever counter-clockwise against the slight spring tension, the aperture opens wide and returns to f22 when released. If this is not the case, the problem is in the lens. If this works, then the problem is either in your camera body or in the alignment between the body and lens. Also, the electrical connection between the camera body and the lens is via the five little ball like metal contacts (4 together and one wider spaced) found on the black ring on which the aperture ring is located. If either these contacts or the contacts on the camera body are dirty, the automatic functions may fail. DO NOT use any liquid cleaner. Gently rub the contacts with a rubber pencil eraser, being very careful to hold the camera body or lens in a position that will allow any debris to fall downward away from the body or lens. Do not overdo it. If this does not get you on the right track, let me know what you find and we will proceed from there.
P.S.: Have you made sure you have fresh batteries in the camera?
Posted on Nov 28, 2008
Lens is stuck open ,will not close,what would be the fix and how much at a authorised Nikon repair service
That depends on what is causing the Jam, there are a lot of things that could cause that. Any good repair store will be willing to give you an estimate repair cost.
Mar 04, 2011 | Nikon 105mm f/2.8G ED-IF AF-S VR...
I set this "Nikon 105mm f/2.8G ED-IF AF-S VR Micro-Nikkor Lens" or tried to set it to F2.8 in full manual mode. the F-Stop wandered from F2.8 to F3 / F4.5 depending on where i pointed the lens. I...
You have described Aperture priority mode: you set the f/stop and the shutter speed changes to make the exposure correct.
Full manual mode requires you to set both the shutter speed and the f/stop. You are seeing the recommended f/stop for the shutter speed you have selected.
Sep 25, 2010 | Nikon 105mm f/2.8G ED-IF AF-S VR...
Image is too dark nikkon swm vr ed
Having received no response in over a month, I assume this is no longer a problem.
Aug 06, 2010 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Lens will not open up all the way
Is the maximum available aperture dependent on the focus distance? Many macro/micro lenses "dim" slightly as you focus in close.
See if you get 2.8 focused at infinity.
May 22, 2009 | Nikon Telephoto AF Micro Nikkor 105mm...
Camera will not take picture with nikkor 105mm lens
Check if the lens is properly mounted. If still you get the error message, clean the electrical contacts between the lens and the camera using an eraser. Take care not to let any dust fall into the body. Attach the lens and try.
Feb 10, 2009 | Nikon 105mm f/2.8G ED-IF AF-S VR...
Im looking for user guide for Nikon Micro 105mm 2.8D lens. Where i can find and download it ?
http://mesnotices.fr/annexe_AF%20S%20VR%20MICRO%20105MM%20F%202.8G%20IF%20ED%20LENS%20ERRATA_NIKON_AF%20NIKKOR-_E.htm
or
Jan 30, 2009 | Nikon Telephoto AF Micro Nikkor 105mm...
Putting it back together
In 1965 I did the same thing with a Nikon single focal length lens my F Photomic. This lens was far more simple then a modern AF zoom lens. I had to bite the bullet and pay a camera repair man to fix the lens. He told me that had I not tried to fix the lens myself, the repair would have cost 1/4. The only answer to your question is to take it to a camera repair man and get a quote. I would check the quote against the price of your lens on E-bay and use that to determine if you want to fix your lens or replace it.
By the way, it is very rare for dirt between elements to be so problematic that it results in a degradation of picture quality.
Aug 05, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Nikkor 18-55 lens autofocus problem
That usually indicates that the lens is not communicating with the camera. The contacts on the mount side of the lens may be damaged or dirty. If cleaning the contacts with an eraser doesn't solve the issue, you might want to try another lens to see if the camera is at fault. If the camera checks okay with another lens, then it is likely the the lens needs a new circuit board
Feb 13, 2008 | Nikon D50 Digital Camera with Nikkor AF-S...
Cameras Logo
157 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
