Question about Ambir Technology DocketPort 485
Line showing in copy
I dropped my docetPort and now the copies have a line going down the center and not totally clear copies
    Problem Solver:
  • 5 Answers
You may have broken the lens inside the scanner when you dropped it and that line you are seeing is a crack. I would suggest recalibrating the scanner from within the Custom Setting of the twain interface with a blank white sheet of paper. That may help with the line and quality but that is about the only thing you can do.
Posted on Jun 29, 2009
How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
NP6560 Main Specifications
Main Unit
Type: Console
Platen: Stationary
Photoconductive material: Amorphous Silicon
Copying system: Electrostatic transfer system
Developing system: Toner projection system
Fixing system: Heat roller system
Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
(However, Keep in mind that the paper weight that can be used varies
depending on the type of the Sorter being used.
SADF tray : transparencies and labels
Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
Maximum original size: 11" x 17"
Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
Non-image areas: Leading edge: 1/4" (4.5 mm)
Left and right side: 1/16" (3 mm)
Trailing edge: 1/16" (2 mm)
Warm-up time: Approx. 6 minutes (at temp. of 68°F)
First copy time: Max. 2.8 seconds
[LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
drawer) selected 1→1-sided mode]
Copy speed: Direct (100%) LTR 60 cpm
65 cpm (Accelerated mode)
LTRR 49 cpm
11"X 17" 30 cpm
LGL 40 cpm
STMT 60 cpm
STMTR 60 cpm
Reduction 11"x 17" → STMT 56 cpm (50%)
11"x 17" → LTR 48 cpm (64%)
11"x 17" → LGL 40 cpm (73%)
11"x 15" → LTR 48 cpm (73%)
LGL → LTR 49 cpm (78%)
Enlargement LGL → 11"x 17" 30 cpm (121%)
LTR → 11"x 17" 30 cpm (129%)
STMT → 11"x 17" 29 cpm (200%)
Magnification: Direct 1:1.000
Reduction 1:0.500 (11" x 17"→STMT)
1:0.647 (11" x 17"→LTR)
1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
1:0.786 (LGL→LTR)
Enlargement 1:1.214 (LGL→11" x 17")
1:1.294 (LTR→11" x 17")
1:2.000 (STMT→11" x 17")
Zoom 1:0.490-1:2.040
7-8
Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
Drawer 3, 4 (550 sheets x 2)
Stack bypass (50 sheets; stack approx. 1/4" high)
Multiple copies: 1-999
Power source: 120 V, 60 Hz
Max. power consumption: Less than 2.0 kW
Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
(1169 x 643 x 725 mm)
Installation Space (W x D): 40 5/8" x 28 1/2"
(1030 x 725 mm)
50 3/8" x 28 1/2" (1280 x 725 mm)
[With copy tray (option) attached and stack bypass auxiliary tray extended]
Weight: Approx. 462 lb (210 kg)
RDF (Standard equipment)
Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
11" x 17", LGL, LTRR, or STMT
15-lb to 32-lb bond (52 to 128 g/m2)
SADF tray: 11" x 17" to STMT
11-lb to 110-lb bond (38 to 200 g/m2)
Max. power consumption: 120 W
Original tray capacity: Original tray: 11" x 17" or LGL
50 sheets (20-lb bond or 80g/m2)
LTR, LTRR, or STMT
100 sheets (20-lb bond or 80g/m2)
1 sheet
Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
Power supply: 24 V (supplied from main unit)
Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
(174 x 643 x 539 mm)
Weight: Approx. 56.3 lb (25.5 kg)
These specifications are subject to change without notice.
8-1
ar
Energy Saver
Stop
Guide
Additional Functions
Start
Display Contrast
ii
Enter a ID number with the Number ( 1 - 0 )
keys.
MEMO: ? If you make a mistake entering an ID number, press
the C
Clear
key. Then, enter the ID number again.
? You cannot enter two identical ID numbers.
? If you enter and store "000000" in place of a current
ID number, that ID number is canceled.
? You can store up to 1,000 ID numbers.
Press the [OK] key.
If you want to store another ID number, repeat
steps 3 to 5.
5
After entering all the ID numbers to be stored,
press the ID key. The display returns to the ID
entry screen.
6
Canceling the ID Mode: Clearing All ID Numbers
If you clear all the ID numbers then you can make copies without having to enter an ID
number.
Press the Additional Functions , ID , Stop , and Additional Functions keys in that
1 order.
Clear
Guide
Interrupt
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
iii
Press the [OK] key.
MEMO: ? If you want to stop all the ID#s from being cleared,
press the [C] key.
Press the [CLEAR ALL ID#s] key.
Press the [STORE USER ID#] key, then press
the [OK] key.
All the ID#s are cleared.
If you press the [OK] key, you will return to the
Standard mode.
MEMO: ? Storing all the ID#s under "000000" will also clear all
the ID#s.
iv
In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
999,999). You can view the copy total for each ID number in the touch panel display.
1 order.
After pressing the [COPY TOTALS] key, press
2 the [OK] key.
Press the [?] or [?] key to check the copy totals
for a department. The copy totals can also be
displayed by entering the department number.
Press the Number keys ( 1 - 0 ) for a four digit
department number and it appears at the top of
the display. When you finish checking the copy
totals, press the [OK] key.
Copy Totals (Check Totals)
The following procedure describes how to clear the copy totals for all ID numbers to zero.
Copy Totals (Clear All Totals)
1 order.
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
v
2 the [OK] key.
Press the [CLEAR ALL TOTALS] key. 3
Press the [OK] key.
MEMO: ? To cancel clearing all totals, press the [C] key. 4
The copy totals for all ID numbers are cleared to
zero. If you press the [OK] key the display
requesting the entry of an ID number appears.
MEMO: ? You cannot clear the copy totals for ID numbers
individually.
Dec 21, 2010 | Canon NP 6551 Black and White Copier
My Nokia 6300 is dropped .Then the LCD and replacing case are broken. It still rings and can dial. How can I recover the contact numbers on the phone without DISPLAY? Thanks in advance,
hey
since the phone is ringing and you are able to dial the mother board is intact. you dont need the display i will send the sequence of keys to be pressed which will lead to copying of the contacts to the sim.
then you can put the sim in a different phone and view them.
menu( center button in the joystick key)
up (in joystick key)
center button
center button
top left button( above the call key)
center button
down(in joystick key)
center button
center button
now it will start copying all the contacts to your sim.
wait for a minute or two
and then you have the contacts copied to your sim.
b4 copying clear the sim so that it has enough memory to copy all your contacts
hope it helps
Sep 24, 2010 | Nokia 6300 Cellular Phone
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
HOW TO GET PAGE COUNTER IN KM-1510
Just hold down the stop/clear button for 3 seconds..
It will flash F24 then 3 increments then 3 more.. eg; F24>063>123
It means you have done 063123 copies/prints..
Sep 18, 2009 | Kyocera KM-1510 Copier
Faint red line across page when making color copies or printing in color from computer
Some possibilities are:
1) Dirt on the glass, dirt on the glass strip for the doc feeder, or dust on the mirrors. This would be the case if the line only showed when copying and not printing.
2) Toner dropped onto the charge sawtooth.
This may be possible if the line is intermittent and only showed up for 1 or 2 colors.
Open the front door and remove the waste toner box. To the left of each drum there is a green organ-stop type stem. Pull and reinsert each stem. You will hear a zipping noise. These are your charge scrubbers.
This may be not as likely if the line shows up in the same place on all 4 colors
3) Toner or dust on the lens
In the area where the waste toner box goes, look for a grey stick with a white cushion on the end. This is your lens scrubber. Look in the area under the charge scrubber on each drum cartridge for a gap. Insert the scrubber cushion side down into the gap and run it forward and back to clean the lens.
4) Transfer belt blade not cleaning
This is best handled by a service tech since the mylar belt is very fragile. The squeegee blade that cleans the transfer belt between copies is missing a spot. The blade needs to be taken off the belt, cleaned and repowdered. Recently, Sharp made changes to the composition and thickness of the mylar in the transfer belts. Overpowdering the blade or belt when it was changed may cause improper cleaning of the belt creating lines across the copies. Often the condition clears up after a couple of days as the gap between the blade and belt is sealed.
This is most likely the cause as the line shows up in the same area for more than 1 color.
5) Transfer belt and/or blade is worn out
If the belt is worn the blade must be replaced but not vice versa.
6) Clogged waste augers in the drum cartridges.
Waste toner may cake up in the drum cartridge and knock loose on the drum.
It may be time for full maintenance on the machine.
Jun 02, 2009 | Sharp MX-2700N Color Copier
Hi there, ive got a sony ericsson and its crapped itself
If it's a z310a (which it probably is, since a lot seem to have this screen problem) I can help you save your contacts to your SIM card so you can put them on a new phone.
To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
May 31, 2009 | Sony Ericsson Z310i Cellular Phone
My inside screen will not show anything. i can receive and send calls bu dont know who im calling. ive never dropped it, gotten it wet, or damaged it in any way .help
Jan 08, 2009 | Sony Z310a Cellular Phone
Black Line Down Center of Page
I had the same problem. I cleaned the strip above the glass and this fixed the problem. Hope it helps!
Feb 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Black line on my fax copies!
You sure can - the issue is that there is something on the thin strip of glass where the copy goes through from the feeder at the top - follow these directions and you should clear the problem right up.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Jan 22, 2008 | HP OfficeJet 6310 All-in-One Printer...
Ambir Technology DocketPort 485 Logo
Top Ambir Technology Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Ambir Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
