my ge oven doesnt work. the top burners work just fine but the oven will not light. i checked the gas shutoff valve to make sure it wasnt closed.what should i check next?? pls help. when i set bake 300 on oven i get nothing. the ignitor does nothing. if you have any suggestions i would appreciate it.thank you
Hi I have a GE Profile Range. My burners work but my oven AND my broiler does not. Would the ignitors of both go at the same time? What do I check for?? thanks
Ted, you probably have a bad ignitor. If you have a meter, you can do some checks to rule out the board. Take the back top panel off and on the board you will see four wires..from left to right they should read L1, neutral, broil and bake on the board. Broil and bake will be marked as BR and BA. Set the oven to 350 and press bake, you should have 120V from BA to Nuetral. If so your board is ok. You should also hear a click after pressing bake. 90% of the time it's the ignitor, part number WB13K0004. Be care when testing with live power. Catriver..post back.
Was this solution helpful? Show your Appreciation by rating it:
