Question about Refrigerators
GE Profile side by side 24 cu ft TPX,with ice maker
Ice maker will ot make ice. These are on frige door: TPX24PR, TPX24BR, TPX25BI, TPX24SI te unit is approximately 5 years old.
Thank you, Cynthia Johnson
cynde.j@sbcglobal.net
  • Anonymous Feb 23, 2009
    same problem.need to know which ice maker replacement I need.
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
  • 13433 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Posted on Sep 08, 2008
MNTECH
  • 1543 Answers
SOURCE: Ice maker only makes crushed ice
Pull the ice bucket out. Behind it you will see a rectangular hole with a rod in it. The rod should be able to move with your one finger up and down. If it does not, the solonoid attached to it is either frozen or burnt out.
Posted on Nov 25, 2008
  • 56 Answers
SOURCE: Hello, I have a GE
You can possibly burn out the solenoid valve. There is an off position on the ice maker itself and possibly a switch to turn the power off to the IM.
Posted on Dec 08, 2008
SOURCE: I want to remove the motor drive in the freezer
I would be inclined to simply remove power to it, unless you are trying to make more space inside.
You may find useful info in the manual (link working 2nd-may-2011):
http://www.managemylife.com/mmh/owner_manuals/4766/KENMORE-Side-by-Side-Refrigerator-L0311310?brand_name_search=592099
Keep in mind that older fridges and freezers were made with some nasty chemicals for the refrigerant, if you pierce the plastic body with anything make sure you get the room well ventilated at a minimum and keep any family well out the way while your repair it.
Posted on May 02, 2011
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Profile water pouring from ice maker
shut off the water to the unit and sounds like either the disp switch is stuck or the water valve faulty.
Apr 02, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge 26.6 cu. ft. side by side refrig- TFX27R- the ice maker just stopped working.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 23, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile Artica, MDL# psc23mgnabb, ice maker won't make ice, plus refrigerator side is freezing the contents
heatman101
Aug 27, 2010 | GE Profile PFS22 33" Artica French Door...
Ice maker is no longer working
heatman101
hfdhjd452
Jul 26, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice machine not working
inside your dispenser, on the front door it is solenoid valve, it got rusty and stock slosed so you need to replaced it....it is a common problem for GE Profile..about $20 for part can be messy but i hope you can handle it
Aug 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker will not eject ice cubes in GE Profile gss25tswass
Empty all ice from the bin and from the "Drill" like Ice shaper spinning unit. Let the unit make some new ice and see if that works.
Feb 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile refrg. with ice maker
Too much ice, maybe the ice maker didn't connect right, the gears moves but the spring inside the ice maker won't move.
Jul 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
353 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
