Question about Fuji Pictrography 3500 Printer
Pg 3500 check magazine d
I bought a 3500 off of ebay plug it in and got a message to check the donner mag. I have removed, reinstalled, cleaned every thing I can find any Ideas would be greatly apreciated.
0 characters
1 Points
Using old but good printer. Just purchased black cartridge (PG-40) but when I went to install it there is already a coloured CL-51 coloured cartridge and a CL-52 Photo cartridge. There's no space for the...
Hi Wendy,
According to the user guide for your printer, the only 2 cartridges that you can use is CL51 and CL52. From my references, the PG-40 cart doesn't go to your printer. If you are having trouble with your printer printing black, then you would have to replace the CL-51 Cart. I would make sure that the heads are clean before running out for a new cartridge. You should be able to do a "Printhead Clean" from the settings.
Hope this helps.
Let us know if we have helped you with your question.
Mac =)
Oct 01, 2013 | Canon Pixma iP6210D InkJet Photo Printer
I recently changed from Preface to ID Works for printing my cards. At the same time I installed the Datacard printer driver ver 4.0 from CD. I have a SP 35 with and optional mag stripe kit installed. Now I...
Most likely your Mag-stripe info is missing from the card project in IDworks.
If you imported your projects from preface, its likly the box to include mag-stripe config was not transfer d.
enter idworks designer and click VIEW then field connections, there should be some info tied you mag-stripe field 1,2, or 3 of not there is the problem.
Next check printer plug ins in IDworks admin to make sure the mag-stripe plugin is installed. Also i would check Download section make sure you have newest and correct driver for your OS
if none of this works, uninstall everything (exporting projects) and reinstall.
Mag-strpe encoders can become defective, the encoder may need to be replaced.
Jan 02, 2010 | Datacard SP35 Printer
Error Message: Remove and Check Cartridge. Check
Same problem!
What's the sollution without having to buy new cardrigdes?
Nov 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
Replaced black cartridge in my lexmark 3500-4500 printer. message reads "left cartridge incorrect". Have taken cartridge out and put back in numerous times still get this message.
You may have bent or broken a sensor wire. Check how the other (color) side looks by removing cartridge and confirm that nothing is awry. Otherwise, clean the metal contacts on both printer (power off and unplug) and cartridge with rubbing alchohol and a cotton swab, then try again.
Aug 18, 2009 | Printers & Copiers
Printer message reads left cartridge incorrect lexmark 3500-4500 series
I suggest that you reinstall that printer.
First, please follow the steps below to remove the existed printer driver.
1. Click the "Start" button, type PRINTER in the search box and press Enter.
2. Find the icons which are related to Lexmark 3500/4500, and delete them.
3. Right-click on the blank part of the window, and choose "Run as administrator"->"Server Properties".
4. On the Drivers tab, select the listed printer and click the Remove button. Please then select Remove driver and driver package.
5. Open Start menu, input APPWIZ.CPL in the Search box and press ENTER to launch "Programs and Features".
6. Try to remove all related printer software.
Then, download the latest driver from the following website and install it.
Lexmark - United States - Product Selector
Aug 03, 2009 | Printers & Copiers
12a cadridge refilling process by syed khaja moin from india
Separate cartridge into 2 sections -drum /cleaning section, and toner hopper.
Replace drum and cleaning blade, clean PCR.
Remove Mag roller. clean out toner hopper, clean mag roller, replace doctor blade, fill with toner, and reassemble
Apr 12, 2009 | HP LaserJet 1020 Printer
Remove & check cartridge message
What you could try do is to remove both cartridges, close cartridges cover
Unplug printer for awhile, at least 30 minutes
Plug in printer and wait until printer stop
Reinstall both cartridges
This is to let the printer reset and do a new installation of ink cartridges
Feb 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Fargo Pro-L error message Mag Jam.
May 29, 2008 | Fargo Pro L ID Thermal Printer
Mfc 210 nor working
make sure that you are using genuine Brother ink cartridges.what is on the lcd screen of the brother machine?if no cart,remove all cart.reinstall them.if there is an error message,sorry,but you have to replaced.and your brother machine does not have a green only has cyan(blue),mag(red),yellow and black.there is a way of cleaning it though
May 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Fuji Pictrography 3500 Printer Logo
24 people viewed this question
Top Fuji Printers & Copiers Experts
isaac johny
isaac johny
Prashant  Sharma
Prashant Sharma
Are you a Fuji Printer and Copier Expert? Answer questions, earn points and help others
