Reply to Sparks coming out of the DC pin when battery was getting low
Thanks for getting back. Since I wrote my question I learned that the DC pin or where I plug in the electrical cord is part of the mother board. So even though the
adapter is broken off internally I am told I have to replace
the whole mother board and that runs big time dollars.
The computer works fine when it runs just on the battery.
But the battery is now drained and needs some juice.
  • lawner Nov 09, 2008
    Thanks for your advise and help. I learned that the motherboard is ok it just requires the DC pin to be resoldered to the board. I have knowledge how to solder small items and worked with a soldering gun before. Just dont know whether it would be a hassle for me to take the laptop apart to get to the area that needs to be soldered.
  • lawner Nov 11, 2008
    Thanks for the descriptive suggestion. Even though I have experience soldering things and taking things apart the risk in taking apart a laptop for the first time may be too high and it would be best to have one who has more experience to open the laptop and to perform the soldering job. I will call it an insurance policy. If I mess up I may lose everything or run into more expensives.
  • 128 Answers
Too bad can't help you out with the motherboard man! guess you'll have to find a way to charge your battery.
Posted on Nov 07, 2008
  • cpenny29 Nov 11, 2008
    well, in disassembling laptops, you need to take extra careful.
    depending on the make, you can try removing the plastic cover on top of the keyboard area. keep in mind that these plastic that covers the whole laptop are clipped together so there are no screws so be careful not to break it.once you've removed it you will see the screws that holds the keyboard so you need to unscrew that and gently lift the keyboard slowly and you will see a ribbon cable attached to the keyboard and to the motherboard. detach that cable and remove your keyboard completely and set aside.from there you can check if you can see the adapter terminals.
    Good Luck to you! (you'll need it!)
  • cpenny29 Nov 12, 2008
    well, i'm glad you took that into consideration!
    good luck in your laptop!
    just remember, we're here to help!
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
Dell laptop latitude C640 model pp01L will not charge or boot
1) Check the AC adapter (Charger) to see if it is putting out 20 Volts DC.
Use a multimeter with the Function knob set to DC Voltage. If just a symbol, the symbol is a dotted line over a solid line.
If there is a multiple setting for the Function knob with DC Voltage, set it to the 0 to 50 Volt (DC) scale.
If you do not have one, or access to one, an economical yet reliable multimeter, can be purchased for as little as $10. (Less in some places)
A multitude of stores carry them. An auto parts store is but one example.
Analog or digital doesn't matter.
http://www.laptoppartsnow.com/uhsdfsrzdgir779.html
This is the DC Power Jack. May be labeled as DC IN on the laptop,
http://www.discountelectronics.com/index.php?l=product_detail&p=14640
I want to show you it, and have you look at the cable end, that is coming from the AC adapter (Charger) TO the laptop.
(To the DC Power Jack)
See the 3 pins? Arranged in a triangle? Note the socket holes in the cable end.
The pin that sits all by itself on Top, is the Positive pin.
The two pins down below are Negative, or Ground, pins.
The Positive (Red) probe lead of the multimeter, is inserted into the single socket hole, in the cable end.
The Negative (Black) probe lead can go into any of the two bottom socket holes.
Read very near 20 Volts?
Have an assistant wiggle both cables. First the one from the charger To the laptop, then the one from the charger to the wall receptacle. (Or surge protector, actually)
2) Charger checks out?
Go to the DC Power Jack.
You may wish to skip checking the charger out first, and check the DC Power Jack, if you Know that the charger is good.
Battery removed see if you can wiggle one of those 3 pins around.
Be gentle, use a pencil if available.
ANY perceptible movement means a Problem.
Looking back at the second link above showing the DC Power Jack, note the metal prongs coming down towards the bottom of the jack.
There are 4.
2 on each side.
Note the 3 long pins sticking down towards the back of the jack.
The 4 outside prongs made from the outer case, are used to anchor the jack into place. They go down through holes in the motherboard, and are soldered on the opposite side.
There may be Ground attached to the case through these prongs also.
The two pins sticking down towards the Back of the jack, are also Ground pins. (Negative)
The single pin by itself is Positive.
A) IF, any of the pins wiggle, the jack is broken, and needs to be replaced.
B) IF, the outer shell of the jack wiggles, the jack May just need to be soldered back into place.
(Could also be an indication of more damage than appears to the eye)
Same thing for the single Positive pin solder joint.
Charger checks out, DC Power Jack checks out, the problem may be a bad power sensor chipset.
This chipset senses when the laptop battery needs a full charge, or a trickle charge, or no charge.
This means it also will sense when the laptop is to be run straight off of the charger, and not the battery.
Usually means motherboard replacement, unless you have access to the chip, and means to replace it. (Soldering tools, and technique)
Appreciate it if you would keep me apprised as to what you find.
Post in a Comment.
Regards,
joecoolvette
Jan 23, 2012 | Dell Computers & Internet
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
Dc jack of labtop getting vey hot
A common weak spot on most laptops is the DC power jack. If someone trips on the wire while you have the power adaptor plugged into your laptop, chances are that the power jack will get damaged.
On most laptops the DC power jack is soldered directly to the motherboard and there are only three or four small pins holding it in place. Unfortunately that makes the power jack quite weak. Any sideways pulling of the DC power cord while attached to the laptop will usually dislodge at least one of these pins, breaking the solder around it. Modern laptops use quite a lot of power, from about 70W to 120W or even more. The bad electrical connection from the dislodged pin will cause sparks and heating that will eventually burn a hole through the motherboard and can even be a fire hazard.
The usual signs of that are:
  • The battery is not charging properly or stays at half charge despite that you have been using the power adaptor.
  • The screen flickers (the brightness is changing) while the power cord is plugged in. This is caused by the laptop switching between DC power (screen is brighter) and battery power (screen is dimmer).
  • The DC plug gets hot after a few minutes of use and may even smell of burning.
  • There are "scratching" sounds coming from the DC jack.
You need to take the unit apart and check/resolder the DC jack on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 15, 2011 | Computers & Internet
Set will not come on only 2 yrs old remote or front panel controls will not help unplugging and re pluging has no effect with back cover removed center power board and all side boards so no...
Do you get any DC outputs from any one of the power supply DC output connectors? No blown fuses and caps in the power supply, Y and Z sustain boards?
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Parts: www.shopjimmy.com
Please post back what you find.
Please leave rating if it helps.
Jan 14, 2011 | Vizio VP322 32 in. Plasma TV
My Dell 1525 has stopped being able to use the power cord for charging all of a sudden. Could it be a short or something?
Sometimes this happens to "generic" chargers, which come with the laptop. Also, it could be a shortage in the wire, check it to see if there are any rips, tears, holes, etc. If you see/hear sparks, your charger is definitely ruined. The most I can say is buy a replacement charger and also don't share your charger with people who have a laptop of a different manufacturer/brand, it shorts it out real fast.
Hope I was a help!
Jan 03, 2011 | Dell Inspiron 1525 Notebook
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Setting up a 70-382B and 70-530B Radio's as link radio's on an Amatuer Repeater
Pin 1 auxillary 1
Pin 2 mic hand up ground
Pin 3 Mic hang up center conductor
Pin 4 and 6 for external speaker
Pin 5 and 6 jumpered together for internal speaker
Pin 7 Ground
Pin 8 not shown
Pin 9 13.8v DC
I have the manual for the 70-382B/482B but for shop use only
I'll help you with any information I can.
Pat N5SLI
Dec 23, 2007 | Midland Amateur&Consumer Radio Replacement...
Low battery
unfortunally it's a bad camera, better to buy a new one with AA batteries.
Sep 12, 2005 | BenQ DC C50 Digital Camera
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
