Question about Lenovo 3000 N200 Notebook
Lenovo 3000 N200 0768HCQ- does not boot after Lenovo Splash Screen
Hi !
I have a just out of warranty Lenovo 3000 N200 0769HCQ. The system had a constant problem for freezing for a few minutes. My usual habit was to simply switch off the system and switch on as a fresh boot. But the last time i did it, it just came with the Lenovo splash screen and did not go any further. My hardware guy thought its a Bios issue and updated the same but it now goes to a next screen but does not detect the hard disk and hence no OS to it may Boot. I was advised by the Hardware vendor that its a mother board issue and hence its looking expensive to mend it. pls advise what could be a possible solution
  • Anonymous Dec 16, 2008
    it does go to the windows xp bootup, but restarts even before the login page
  • contracts Jan 03, 2009
    i upgraded bios to a newer version on my lanovo 3000 n200. the upgrading was successfull. when it rebooted, the windows does not start and it shows me a blue screen with dump memory or something and then it restarts again. then i tried to install new windows and the setup says that no hard drive found. i mean WTH! can anybody plz help me here!!!!
In bios version which is you installed is vista compitable so go to bios setup there is option by which your harddisk available for you at present i am not able to tell the name of that option(forget) but i have tested it.
Posted on Dec 28, 2008
How do I log in to safe mode on Lenovo g585 laptop?
Hi Sarah,
When you boot up the laptop and the Lenovo splash screen shows, press F8 and it will give you the option to boot into "Safe Mode"
Hope this helps:)
Thanks,
Gary
Oct 17, 2013 | Lenovo G585 Laptop
Iam using Lenovo G550 today system is not booting screen totally blank all Led was on but system is not booting screen totally even hardisk, posser also not responding let me know what is the exact problem
Hi and welcome to Fixya!
If the issue with your machine is just caused by a glitch, try to do power drain.
1. First shut down the machine and unplug the adapter and take out the battery.
2. Press and hold the power button for 10 seconds.
3. Then put back the battery and plug back the adapter. Try to turn on the machine normally.
If this does not solve the issue, it could be caused by a problem with the motherboard. If your machine is in warranty (or even if its not), contact Lenovo warranty support on this number - 1 877 453 6686.
Hope this helps!
Takasashi
Jul 13, 2011 | Lenovo G550 Notebook
My lenovo ideapad y560's monitor won't open. the monitor is pitched black.
Hi thelzy,
I see that your Lenovo Y560 is having issues showing no Video, you mentioned that you only get a Black screen when booting.
I am assuming that there is still power on the machine but no video at all, Just to ask do you still see the Lenovo Splash screen? if not then we can try doing a power cycle on the machine.
* Remove the battery on the system unhook the Power Cord/AC adapter as well then press and hold down the power button of your Y560 Laptop for about 15 seconds then let go.
*After Doing the Power Cycle connect the AC Adapter again but leave the battery out for the time being then turn the compute ON, check to see if it will show the Lenovo Splash screen if it does then we're in progress and should show windows Loading up on the LCD screen.
*If it does not show the lenovo Splash screen then most probably the BIOS screen never showed as well on the issue.
*Connect the battery back n the machne turn it ON again check if it will show anything on the screen, if not then see below.
*We can try connecting an external mnitor to the system using a VGA connection it should show us the Screen on the external monitor if not then it means that Windows as well is not booting on your Laptop.
*Check the indicator Lights on the Laptop, one of the Lights will be a cylinder icon on the Laptop check if there is any activity from that light if there is no Light or any avtivity to any of the indicator lights then your Y560 is having issue with the Motherboard.
I hope this info Helps.
Have a nice day.
mvincentc
Apr 21, 2011 | Lenovo IdeaPad Y560 Notebook
Lenovo comes on but screen is black
This is a no display issue. If this system is still under warranty please call Lenovo Warranty Support @ this number for depot service. 1-877-453-6686
Feb 27, 2010 | Lenovo 3000 Y410 Laptop
It starts with the lenovo screen and then goes to the Windows XP screen but it goes back to the Lenovo screen. What can I do so I wont have to restore my system again?
ok, press f8 key as the system is booting up, this will put you in safe mode,
if the system boots okay goto command prompt mode and type chkdsk /r to repair any files etc ,
Try booting up again, if the problem is the same then it a startup file that need repairing so goto safe mode, command prompt type bootcfg etc and try repairting it that way, us e the help command to point you in the right direction.
Regards
GeWiz
Oct 01, 2009 | Lenovo 3000 C200 Notebook
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Blue screen on Lenovo t61 laptop
check first the program or operating system.
re instal if needed
Sep 12, 2009 | Lenovo ThinkPad T61 Notebook
SMPS BURNT OUT
Does your laptop works on battery?
Do u mean to say that your adapter burn?
if so please replace the adapter.
There should not any problem related to booting of your computer as far as the Adapter concern.
Apr 12, 2009 | Lenovo 3000 N100 Notebook PC
Hard Drive Upgrade Process on Lenovo 3000 V100 - Hangs on restart
yes..you hit it right on the nose..that needs to be done first, otherwise the Lenovo Bios will simply loop..
Jun 15, 2008 | Lenovo 3000 V100 Notebook
Lenovo 3000 N200 Notebook Logo
681 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
