Question about Casio Parts Cash Register PC Desktop
TK4000 not registering dry cleaning items - electricity was off for a while
Used in dry cleaners - electicity supply was off for 1/2 hr when it came back nothing works - i think i may have to re-enter each item but the decimal point shows ie 1.2000 - how can i change
  • 737 Answers
Hi.
This usually means the backup battery has failed, and didn't hold the programming when the machine was off. You have probably lost everything including the system programming. It will probably have to be RAM cleared and setup again. If the dealer has a backup of your program, you can get it put back in. Otherwise, they can go through the system prog tables and set it all up for you again.
Mark
Posted on Nov 07, 2008
How do I clean the inside glass on my electric fireplace
To remove any dust, simply use a clean, dry cloth to wipe down the interior. Gently dust any media such as logs or glass inside your electric fireplace as well.
Cleaning Steps
1.Disconnect from Power Supply Before beginning to clean your electric fireplace, turn the heater off and allow to cool completely. Always disconnect the electric fireplace from the power supply before cleaning.
2.Check the Electrical Components Check any wires and plugs to make sure that they are not worn or frayed. This is a rare occurrence, but can become a fire hazard if not addressed. If this happens, consult a professional to repair or replace before using your electric fireplace again.
3.Clean the Heater With a clean, dry cloth, wipe down the surface of the heater. Using the soft brush attachment of a vacuum cleaner, gently clean the heater outlets. This will remove any dust or debris from the heater and keep it running at top performance.
4.Clean Both Sides of the Glass Follow the instructions in your owner's manual for removing the front glass panel. Once removed, you can clean both sides of the glass. Do not use abrasive cleaners, as they will scratch the glass. Dust can be easily removed with a clean, dry cloth. Fingerprints or other marks can be removed with a damp cloth; dry the glass with a lint free cloth to prevent water spots from forming.
5.Dust the Interior Dust may accumulate inside your electric fireplace, like any other unit in your home. To remove any dust, simply use a clean, dry cloth to wipe down the interior. Gently dust any media such as logs or glass inside your electric fireplace as well. When you are finished, place the front glass panel back onto your fireplace following the instructions in the owner's manual.
6.Remove the Soot Just kidding! You never have to worry about dirty, grimy soot with your electric fireplace. Instead, just relax and enjoy!
Nov 14, 2017 | Miscellaneous
How do i clean the mass air flow sensor on a 1988 3.0 v-6 4x4
These are best cleaned with spray brake cleaner.
Oct 14, 2015 | Cars & Trucks
Tefal repairs
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wat
Nov 29, 2013 | Irons
Drying take 2.5 hr to complete. Can I have an
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I was cleaning life fitness 9500 hr with an acid base cleaner, and control panel is not working any more, buttons do not respond, can turn it on though
I'm sorry to say that using the acid base solution destroyed your function pad and will need to replace. Any clean must be done with simple green or warm gentle soapy water. Contact Life Fitness1-800-351-3737 or Nation Gym Supply 1-800-496-7278 give Model and Serial Numbers. Either company will help you.
May 09, 2010 | Life Fitness 9500HR Next Generation...
Hello expert
try cleaning it before you mess with any settings.
Cause:
Your keyboard or number pad may collect dust and other deposits from regular use. Occasional maintenance helps keep the device looking clean and functioning properly.
WARNING: Before cleaning any electrical device or equipment, ALWAYS remove the device from its power source.
Solution:
  • For cordless keyboards or number pads, remove all batteries before cleaning.
  • For the diNovo Edge (a rechargeable keyboard with a built-in, non-removable battery), or any other similar device, switch the keyboard OFF before cleaning.
  • For corded keyboards or number pads, shut down your computer and disconnect the keyboard from the computer before cleaning.
Keyboard and number pad cleaning suggestions:
  • Use compressed air to blow dust and other debris from between the keys. Logitech suggests using an air duster squeeze bulb specially made for keyboard cleaning to limit the force of the air pressure.
    NOTE: Avoid using high pressure air hoses and nozzles. Excess air pressure can remove keys or cause other damage to your device.
  • Use a small tipped vacuum cleaner to remove dust and other debris from between the keys. Logitech suggests the use of a small tipped vacuum cleaner specially made for keyboard cleaning. Many come with USB power cords and can run off your PC or laptop.
    NOTE: Avoid using vacuum cleaners other than the type previously described. An excess vacuum level and/or large vacuum tip can remove keys or cause other damage to your device.
  • Use a dry, lint-free, non-abrasive micro-fiber cloth to gently wipe clean the surface of your device. Logitech suggests using cloths which are specially made for keyboard cleaning.
    Note: Avoid using dusted disinfectant cloths or cloths dampened with liquids unless specifically designed for keyboard cleaning. Many cleaning solvents, chemicals, and other liquids can cause electrical and/or material damage your device. This includes leftover residues which can eventually damage your device over time.
Additional information:
Many consumer electronics stores and online re sellers offer third-party computer cleaning kits which include dry wipes, swabs, air duster bulbs, and micro-fiber cleaning cloths. Some higher-end cleaning kits come with keyboard vacuum cleaners, and/or product-safe disinfecting liquid for dampening wipes, for use in disinfecting the surface of the device. These liquid disinfectants are supposed to be non-conductive electically; quickly evaporate from the sevice and leave no residue. Logitech suggests you make sure these characteristics are plainly stated and guaranteed on the product package. These specially made keyboard cleaning kits are highly recommended.
IMPORTANT NOTES:
  • DO NOT pour any liquids onto the device.
  • DO NOT submerge the device in any liquids.
  • DO NOT use a dishwasher, ultra-sound cleaner, or any other washing machine to clean your device.
  • DO NOT remove keys from the device.
  • DO NOT use cleaning solvents. Many cleaning solvents contain caustic chemicals which may cause damage your device.
  • DO NOT use drying machines, fireplaces or ovens (even set at lowest temperature) to dry moisture from your device.
Removing keys; submerging or pouring liquids on your device; using washing machines; exposing your device to excessive heat; or using caustic cleaning solvents may cause permanent damage to your device and will void the warranty.
Feb 27, 2009 | Logitech Cordless Desktop MX 5500...
Jenn air range
1.black top nice and shiny, as far as streaks your gonna ahve to find a cleaner that works for you , i have a black cooktop and my wife uses clorox wiped to clean and then with paper towel wipes off and dries
2. as far as "saddle grill" calling the manufacture (number inside your manual) will be best source of info on that, of course unless you can find an aftermarket 3rd party maker
Mar 15, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Brother Intellifax 775
1-use air blower to clean it.
2-use dry contact cleaner to clean it.(radio shack)near to you.
3-if you have previous experience in machine open it and disassemble key pad -wash it carefuly with water and dry it and bring a tracking pen(also from radio shack and apply the pen in pads of numbers 1-2-3.
Mar 04, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Deep hard core cleaning
From GEAppliances.com: Microwave - Cleaning Recommendations To minimize the possibility of electric shock, unplug the microwave from the power supply before attempting any maintenance or cleaning. Spills and spatters clean up easily with a damp, soapy paper towel or sponge. It is best to clean soil as soon as it appears. Baking soda and water may also be used. If the food has cooked onto the interior, heat one cup of water on full power for three minutes. The heat and steam help to soften the food. After the three minutes, allow five additional minutes stand time then clean as usual. A non-abrasive scrubbing pad cleaner works well for stubborn stains. You may use mild dish washing liquid or cleaners specifically listed for cleaning interiors of microwave ovens such as MicroBryte® (wx10x3030) or Microwave Oven Magic®. We do not recommend using other detergent based cleaners because they can cause the plastic parts to crack. You may purchase microwave interior cleaner by calling our parts department at 1-800-626-2002, on-line from GE Parts or from your local grocer. For stainless steel interiors of microwave/convection models, we recommend a plastic, soap-filled scouring pad. Rubbing gently with this pad will help remove soil. For the door surfaces (both interior and exterior) We recommend you use only mild, non-abrasive soaps, or detergents applied with a sponge, or soft cloth. For the control panel Wipe with a soft, damp cloth. Dry immediately with a soft cloth. Do not spray any solution directly onto the controls Important: Commercial Oven Cleaners, abrasive cleaners, or cleaners containing ammonia or bleach (can make the plastic brittle) should not be used on any part of the microwave. -- From me - Maybe local restaurants in your area would have some tips? Otherwise, try a Google search for keywords: cleaning stainless steel oven
Aug 05, 2007 | GE Advantium 120 Convection/Microwave Oven
Casio Parts Cash Register PC Desktop Logo
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
