Question about Motorola Lands Phones
Having Problem with STU III/A SEC TEL, DSP 5600I, MOD 5DGL15526XA, GSN: STUB2600003999, Need Phone Support Telephone Number. Joseph Valenzula, Raytheon, 520-794-2703
4 Suggested Answers
  • 2072 Answers
SOURCE: Canon MF 3200 Series
There should be a setting, most likely under advanced fax settings that is called Rings To Answer. That normally can be adjusted from one to seven rings.
Posted on Feb 25, 2008
  • 12 Answers
SOURCE: can you please tell me
If you select a hot wash the tub will fill with hot water from your boiler only on main wash. See how many buckets of water that takes to fill to that level. Then depending on how many times you use the machine a day, that will answer your plumbers questions.
Posted on Nov 13, 2009
FixinFax
  • 3085 Answers
SOURCE: Keurig Customer Service Telephone Number
1.866.901.BREW (2739)
Posted on May 26, 2010
What is the unlock code for Orange locked Samsung S3650?
download the latest version of mini militia mega mod apk here https://trickshive.com/mini-militia-pro-hack-mod-apk-download
Aug 10, 2014 | Samsung S3650 Corby / S3650 Genio Touch...
What is wrong when the phone says Check tel line?
The telephone cord may not be connected correctly.
  1. Unplug both ends of the cord connecting the wall jack to the telephone base.
  2. Insert one end of the cord to the TEL LINE jack on the base.
  3. Make sure that the cord is inserted correctly in the TEL LINE jack on the phone.
  4. When you insert the cord you should hear a click.
  5. Insert the other end of the cord to the wall jack.
  6. Make sure cord is inserted correctly.
  7. You should hear a click.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do I set it up as a fax along with my using my telephone on the same phone number
somewhere in the user settings it will have a tel/fax setting wich will allow you to hit "start" to manually receive a fax, also some phone companies can set you up with a distinctive ring for faxing, so you won't need to do a manual receive. when you pick up the phone in the tel/fax mode and hear the fax screech then hit the start button to begin receiving. hope this helps.
Jan 10, 2010 | Brother IntelliFAX 2800 Laser Fax
How do I change the time displayed on the phone?
This Inter-Tel EncoreCX Installation Manual instructs field technicians on the ECX 1000 digital telephone. 40. 618.5015. ECX 1000 Digital Telephone
Here it is:
http://www.homecontrols.com/homecontrols/pdf/EncoreCX-Install.pdf
I hope this helps :)
Jul 29, 2009 | Inter-Tel ECX 1000 Telephone
How do I change information in the Inquiry mode on a Ricoh 2035e.(service contact info etc.)
SP 5812* -1
Service Tel. No. Setting
Service Tel. Number Use this to input the telephone number of the service representative. Enter the number and
press #. This number is displayed when a service
call condition occurs.
SP 5812 -3* Supply
Use this to input the telephone number of your
supplier for consumables. Enter the number and
press #.
Apr 01, 2009 | Ricoh Office Equipment & Supplies
How to program speed dial on sony spp-a946 cordless phone
  1. Press 'PGM'- "program" button.
  2. Press "speed dial" button.
  3. Select "station # " i.e. any button from 1-9 for speed dialing.
  4. (make sure to make a note of this selected # against the corresponding tel # and /or the person's name)
  5. Dial the complete (incl. 1 for USA or country code for other country tel. #s) telephone number to be stored for the selected speed dialing station #.
  6. Press "PGM" button again to complete the storing of the tel #.
  7. Test, after dial tone, by just pressing the selected station #
Mar 13, 2009 | Sony SPP A946 Cordless Phone
Can't dial abroad
how are you dialing the number on the phone, what is the number, if your are not dialing it correctly it will cause this,
i.e i believe austria is 00 + 43 + Area Code+ Tel #
and norway is 00 + 47 + Area Code+ Tel #
if you go to www.countrycodes.com this will help
Jan 01, 2009 | Lands Phones
Audioline 20 Memory Speakerphone
1. Lift handset (releasing hook switch).or just press SPEAKER, ignore any noises or BT messages while you..
2. Press and release STORE key.
3. Press the keys for the telephone number
you wish to store.
4. Press and release the STORE key again.
5. Press the keypad number (0-9) you want
that telephone number stored in.
6. Your number is now stored.
Apr 01, 2008 | Audioline TEL 100 Plus Corded Phone
Feb 25, 2008 | Office Equipment & Supplies
Lands Phones Logo
Top Motorola Lands Phones Experts
David Payne
David Payne
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
