Question about Xtreme Sound Car Audio & Video
Unable to remove cd magazine
I have a extreme sound cd changer and I am unable to remove the cd magazine.
    President:
  • 624 Answers
The reason for this would most likely be that there is a disc stuck in the cd mech that has not returned to the magazine. It could also be a bad gear or belt, in fact there are a variety of things that can cause this. Unless you have some experience with this, I suggest that you take it to a service center. Ask them what they would charge to remove the magazine only and then return it to you. Sometimes they get stuck for odd reasons that may not happen again. If you ask them to just fix the cd changer, you will pay more for the repair if it only requires getting the magazine out to fix it. Then you can put it back in and see if it will work. Try it first with no disc in it, just in case it gets jammed again you will not have a cd in it. If it cycles thru its intialization process and you can still eject the magazine, there is a good chance it will work for you and then try a disc in it.
Many service centers will remove a stuck magazine for just $25 or so, but if you leave it for a repair you will spend much more even if there is nothing more wrong with it. I have been working in this field for nearly 20 years and have worked at 4 different service centers in that time, and every one of them did the same thing.
If the cd changer still doesn't work, take it back and see if they will apply the amount you have paid towards a repair. Believe me, you do not want to start taking these types of equipment apart if you don't need to. You may never get it back together again working right. They can be a real nightmere.
Posted on Nov 06, 2008
Magazine won't eject?
A CD may be stuck between the player unit and the magazine. You can try loading and unloading several times but in extreme cases it is necessary to do some disassembly to get at the disk
Oct 20, 2012 | Clarion Caa-355 6-Disc CD Magazine...
Remove CD Magazine - No power to unit!
u need to re-connect it in order to remove the magazine
Jun 15, 2008 | Sony CDX-646 10-Disc CD Changer
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
Cant remove magazin with cds without changer is on power
Is there a pin-hole on the front of the cassette? If so, insert a paper clip into the hole to manually release the cassette.
Sep 08, 2009 | Panasonic CX-DP88 8-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Manual removal of cd magazine
Seems to me an error of the installers, just go back and ask them to remove the magazine properly.
Aug 08, 2008 | Alpine CHA-1214 12-Disc CD Changer
Need Magazine
Jensen RCH or JCH 10RF and CH1002 disc magazines are the same
Jan 02, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
My actually have a Philips FW C775
Yanking a magazine out while it is in operation is a recipe for disaster. Probably a disc has gotten jammed in transit, preventing removal of the magazine. You probably will have to disassemble the Philips player enough to get access to the area where the CD is jammed, gently guide it into the magazine, then remove the loaded magazine.
Jun 13, 2017 | Philips CDC775 5-Disc CD Changer
Car Audio & Video Logo
348 people viewed this question
Top Xtreme Sound Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Are you a Xtreme Sound Car Audio and Video Expert? Answer questions, earn points and help others
