Question about Mitsubishi VS-70707 70" Rear Projection Television
VS - 70707
When I turn my TV on, there is huge black box the covers all but 1 1/2" border around the image. When I change the channel, the image comes up for a split second, then the black box comes up an covers the whole image again.
    New Friend:
  • 74 Answers
Goto your menu and turn closed caption off, its probably set to 'text1. let me know if this corrects it
Posted on Nov 06, 2008
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
Our toddler pressed several buttons on our Mitsubishi VS-70707 rear projection tv, it powered off now we can't get it to power back on?
Very simple , you need to initialize you tv by pressing menu and input bottoms at the same time for 30 seconds until the picture coming up and select * intitialize* on the screen menu, and wait until is done and you done.
Dec 18, 2010 | Mitsubishi VS-70707 70" Rear Projection...
Black border with some channels
if you mean the left and right sides of screen, look for a button on remote might be labeled several things, like picture size, aspect etc.. the borders pop up when you go to a non high def channel. some chs put borders all around the picture in those cases you won't be able to get rid of those.
Apr 07, 2010 | Memorex MVDT2002 20" TV
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Good day, crsomers1;
The 'giggling' may be a horizontal problem, also known as pie crusting. Try this first: unplug TV from wall, reset or reboot. Secondly: CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
I hope this was helpful, good luck, big IRISH.
Jul 03, 2008 | Mitsubishi VS-70707 70" Rear Projection...
A black box appears on the screen
Just happened to see your black box problem associated with your T.V.; Thought I would pass along an idea for you to check into, and let me know if it helped...Check into whether or not it has a onscreen text block mode, if it gets into this mode by accidentally pressing the wrong buttons on the remote and or TV, it could and I have seen, at least with zeniths, a big black box which will cover the whole screen except for a 2 to 4 inch border around the box and outer edge of the screen...if this is the case, find someone familiar with the correct setting for the set associated with this problem, and get it back into the right mode....Hope this helps..T.
Jan 15, 2008 | Haier 20" TV/DVD Combo
Mitsubishi VS-70707 70" Rear Projection Television Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
