Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Replacing pull string on poulan pro blower
The string came out of the unit. I have taken out all of the crews and cannot pull apart the housing except an inch or two due to the engine. I need a diagram or owners manual to see how to re attach the string. Can you help?
  • 2 more comments
  • Anonymous Nov 29, 2008
    The pull cord will not retract. Is it broken or should I spray some WD40 inside the open area around the pull cord?
  • mfitzsousa1 Dec 06, 2008
    My pull rope will not retract. I've removed all the Allen screws I can access to try to free it, but two are recessed deeply and the wrench won;t reach them. What a pain!
  • Anonymous Dec 15, 2008
    I have a wild thing leaf blower. what is the best way to get to go about replacing pull cord?
  • Anonymous Apr 23, 2009
    Pulled the string to far and need to reinsert it into the unit ant instructions?
Just went through this pain today. Here's how I did it. Use allen wrench with T handle to remove the shroud over the carb controls and plug. Then remove about 10 screws and split the case. Use tool that comes with the unit to remove the nut holding the impeller. Behind the impeller, use torx head to get the other bolts to remove the motor. There are two other screws on the other side that hold the motor on. Drop the motor from the case carefully. It is still attached by wires to the throttle and kill switch. Note how the throttle linkage is connected because it will come apart for sure. On the one side of the housing you are looking at the plastic cord spool with the spring unit behind it. My chord simply pulled out of the spool. It was held on with a 10mm nut and start washer (not a good design). If the chord broke, remove the remnant from the take up spool. To rewind the new chord or replace the one that pulled free, you need to wind the spring to put tension on it. Make sure the take up spool engages with the spring tang otherwise it will turn free and not tense the sprint. Once engaged with the tang, the spool should set to the bottom to be level with the metal chord guide. Turn the spool clockwise 3-4 turns until you feel it tighten. With a 2nd pair of hands, hold the tension on the spool and tread in your chord. Route the chord through the take up reel into the hole on the side. Loosen the 10mm nut with the star washer and route the end of the chord through it. Tie a simple knot in the end to prevent it from pulling through. Tighten the 10mm nut which clamps on the chord. Now, slowly, let the spring tension take up the loose chord until fully retracted. Make sure the metal chord guide fits in the slot to channel the chord properly into the take up reel. Hold the spool down and give the chord a gentle test or two. The chord should retract easily and fully. Simple as pie!!! Reverse the disassembly and you are back in business.
Posted on Apr 04, 2011
The string came out of the unit. I have taken out all of the crews and able to get to the place where the cord came from how do you reattached it. Can you help? thank you
Posted on Dec 06, 2009
I pulled the starter string out. I read some posts on how to fix it, but it looks like the Greek Language. Is there any pictures, diagrams that can help me figure this out ?
Posted on Apr 17, 2011
    Problem Solver:
  • 6 Answers
The carburator and intake manifold have to come off one side, and the muffler needs to be removed from the other side.
Posted on Nov 19, 2008
I have a 2004 Poulan Pro PBV200 leaf blower, and have purchased a new ignition coil. My question is, how do I install it?
you have to pull the whole unit apart
air gap is important so note the gap on the coil before undoing the old one
exploded views
Poulan PBV200 Pro Leaf Blower Parts
you tube link
Poulan pro leaf blower no spark
POULAN PRO PBV200 INSTRUCTION MANUAL Pdf Download.www.manualslib.com > Brands > Poulan Pro Manuals > Blower > PBV200
Oct 13, 2016 | Poulan Garden
Help replace Poulan Pro BVM200
Here is a diagram of the WG500 hope this can be of help.302b8173-0047-4eaa-b003-fb134eb098e4.png
Jul 01, 2013 | Garden
I have a Poulan Pro Blower PPB2000LE rope came loose so I took it a part and now I don?t know how can I rewind the rope with the spring, should I use clock direction or the other direction.
It is not a question of clockwie or not, it depends on the direction of rotation of the engine, they are not all the same.
*wind the rope/spring in the direction that the rope would pull the rope rotor.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Nov 16, 2009 | Poulan Featherlite Gas Blower, with Low...
Replacing pull string on Poulan BVM200VS leaf blower
You will need to split the housing and remove the impeller wheel. In doing this you will have to disconnect the throttle cable and the switch assy. This can be a hand full if you have never done one.
In the future when you are purchasing a string trimmer or blower
or hedge trimmer, be sure that the starter can be removed by
removing 4 screws. This makes starter repair a 5 minute $10 job
instead of an hour $40 or more job. The problem is that you will
not find this in most home centers or box stores. You will have to
go to a full service dealer.
Sep 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Recoil not recoilling good
hey fark
This is easy. Take off rope housing (four screws). Once off, pull the string out 3/4 of the way. Once out, tie string around spindle one extra time ( real easy just wrap string once more around winding spool ). This oughta make string snap back after pulls.
Jun 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro Lawnmower
i have a 950 zx poulan pro lawn tractor. it will start but when i release the brake it cut off . i can start it up with out sitting in the seat.
Jun 14, 2008 | Dryers
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
5,722 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
