Question about HP Compaq nx6310 Notebook
Sound there is no sound at all.but the sound was working properly before until a friend of mine did something(maybe he deleted or format my system).
Sound
Posted on Nov 08, 2008
I just formatted my system and i Windows xp pro
Friend i think it was because of sound driver just go to control panel->sound and audio devices->see if all sounds are in full max then
check properties of sound driver and see if that is working properly and finally update the driver and restart the system if problem persisits ask me again.
Nov 07, 2009 | Edimax EN9130 10/100 NIC PCI (REALTEK)...
No sound
get the driver from HP.com/support
need more help, let me know
Oct 05, 2009 | HP Pavilion dv4000 Notebook
LC32OEM9 says Not Supported Format on HDMI Input. It worked when we first hooked up the TV. Then it started working sporadically now it very very rarely works and when it does it only works for maybe 15...
I'm thinking the Comcast DVR box maybe putting out weird HDMI signals and the TV can't translate it. I would call the Comcast people on this one.
In the meantime, I would try finding another source the uses a HDMI cable to rule out the TV as the problem. Basically, testing the TV to see if the problem still happens when you use something else than the Comcast box. Try a Blueray player, Playstation 3, or Xbox. Just something that uses a HDMI cable.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
My compaq presario f700 laptop boots when it wants
Your system is damaged. You need to have Vista cd. (or xp, or linux, etc) Then you must get to Bios, or bootmenu. When laptop boots, it is on a screen what key to press to make bios or menu running. Maybe f2 or del, maybe f12. When you in Bios, search something like bootmenu, or advanced bios features, then - first boot device. Make it as -cdrom. Press enter or maybe page up/down to change it. Now you must save this by pressing f10 or some key for save, and pressing y. Comp will boot again and run from Vista cd. In its menu you have option repair, but not always this will work (If you doing it with xp, forget to repair Vista). Try this, and if not working, reinstall system on the same partition. Dont format drive, just install, it will give you no loss of data (with xp, i dont think so, you just have to format system partition, but if you have something on second and more, non system partition, dont format it, data on this second will be ok). This it for instalation. After, you will have old vista in some folder (With xp you dont). You should delete this folder when everything works. Do not delete the new one :) No, no, you will find it easy, it should be something like -oldwindows. Better to remove it, cos' it takes a lot of hd. After it all try to find some good antivirus to avoid situations like this.
Apr 09, 2009 | Compaq Presario 700 470024-192 Notebook
My bose car stereo system no longer has sound. When the radio was first turned on, it would take approximately 5 minutes until there was sound coming from the speakers. This got progressively worse until...
i had multiple problems with my stereo in my terrano just recently. first started with the digital trip meter going out and no audio, that was to do with the earth cable which came from te car. on mine it was a pink and silver cable, maybe it was done wrong from who ever wired it in first but it didnt like it so i went straight from the head unit to the chassis... secondly it could be the amp control cable. it may be loose or something. and thirdly a problem my friend encountered with his stereo was that the unit would turn on but no audio and after sctatching at our heads for a while we thought we'd go through from behind the head unit and remove each speaker when we took one out of the equation we got audio and it was because the speaker was shorting against the car body which would prevent any other speaker from working. hope these help. as for the dimming im not quite to sure maybe get a multi metre onto the power and see if its reading 12v.
Mar 19, 2009 | 1999 Nissan Pathfinder
Plz help...
A firmware update. Same happens to my friend's unit yp-u2(x) a 512 mb model.
In XP OS.
1. Download and install firmware updater.(manufacturer's support site)just key in model number and type.
2. Run updater, press and hold play button until its been detected fully by the updater.
3. Check the format box(My friend's unit firmware ver is 1.xxx to 2.xxx something when updated).
4. Hit the update button or something like that. do not detached the unit until its done. Unmount the unit using unmount method "Safely remove hardware".
5. Turn on the unit it should pass the 20 percent mark. When its good it has no file yet coz of format option. Just load your song.
I think it happens when too much file is upload in the unit. 60 percent of its capacity may be enough.
Hope it helps............
Jan 16, 2009 | Samsung YP-U2X Digital Media Player
Sansa E270 Blank Screen and Bad Tracks
well if you can still connect it to your computer just format the mp3 this should work after the format just go to WMP and sync your music
Formating:
1. connect mp3 to computer
2. got to "My Computer "
3. find the mp3 in the computer
4. right click on the mp3 drive
5. click on "Format"
6. click on ok
note : formating will delete all picture,songs, and videos on the device
Oct 30, 2008 | SanDisk Sansa e270 MP3 Player
Pioneer DEH-P8600MP WORKS PROPERLY BUT I CANT GET NO SOUND
My friend maybe you burn out the audio amplifier output
Aug 25, 2008 | Pioneer DEH-P8600MP CD Player
Pendrive is not working
ic, maybe the usb port of your friend's pc is defective which may cause your pen drive to malfunction, probably a shorted usb port. or just maybe your pendrive was dropped by your friend which damage the drive, it happened to me too before.
Sep 18, 2007 | Transcend (589307) Media
Cant Speak On Logitech Internet Chat Headset
Check the plugs on the computer. I have this same headset, and when I first gt it I had made the silliest mistake of not turning it on. A friend of mine had a similar problem, but with the sound. What had happened was, he was doing some cleaning up by deleting useless programs. He had seen a file, but htought it was useless, so deleted that. Later, the sound dn't work, and he had realized that program he deleted was the entire sound file. Maybe the same thing happened, and if it did, you may want to try to get a computer technologist to format your computer, which is basically just you load all of your files onto CDs, back-up hard-drives, or on another computer. Then, they will hack into the computer and make it so that it's almost as if it had just came out of the packaging, and it doesn't know your name or anything. After that, you re-load all the data back on.
Apr 14, 2007 | Logitech Internet Chat Consumer Headset
HP Compaq nx6310 Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
