Question about Integra DPC-5.1 Multi-disc DVD Player
Re: shows mecha error
After playing one out of the 3 cd's (all audio) the display panel shows "mecha error" I have tried cycling the power - but the same problem persists When I turn the unit on, the display panel just shows mechanical error .... the audio cd's are still inside thanks in advance for help/tips Arup
Sony: HCD-GX450 CD player does not work. Display shows mecha error???
May mechanical alignment is wrong . Its good to consult a service tech near to you.
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 10, 2016 | Audio Players & Recorders
E-Mecha...what does it mean?
Hello cclub2002,
First try to turn it off and then on.
If that doasent work, turn it off for 10 mins and then turn it back on.
If the error continues, let me know.
By the way, to try to get your CD out, search for a hole (2 mms in diameter) It should be near the CD tray, but could be anywhere.
Once you locate the small hole, find a paper clip or smomething as pointy as it, and insert the paper clip in.
Press it had and the CD tray will come out.
Good luck and anything else you need let us know,
Jul 26, 2008 | Nakamichi SoundSpace 5 Shelf System
Mecha error, sony microsistem, dont work inside the copact disc
You can try to take unit apart ONLY
if you can reassemble & an clean the eye
with denatured alcohol, any other will leave
a white ressadue. If the eye can't read disk
it won't play an should show an error
Jun 01, 2014 | Sony CMT-HP7 CD Shelf System
Cd won't play or even load - mecha error comes up on display
This message indicates that the loading mechanism has failed in some way. Please update this with the make and model of the unit and I can give you more specific details.
Apr 11, 2008 | Audio Players & Recorders
Shelf cds is blocked SONY CMT-HP7
To get the cds to play, and 5 to eject, you can try taking off the sides of the consul and using compressed air. As for the shelf problem, I'm not really sure.
Nov 09, 2007 | Sony CMT-HP7 CD Shelf System
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
"mecha error"?
i've dismantled my system found the top fuse had blown on the transformer also aligned the cd tray all works sweet now wahoo :)
Feb 11, 2007 | Sony MHC-RG660 CD Shelf System
Mecha error
Mecha error is a Mechanical Error. This means that this is an actual physical malfunction of the unit. Sometimes pressing the reset button can realign some of the mechanics but most often this is a problem that requires to be serviced.
Feb 03, 2007 | Kenwood KVT-717DVD Car DVD Player
Integra DPC-5.1 Multi-disc DVD Player Logo
49 people viewed this question
Top Integra Televison & Video Experts
Are you an Integra Televison and Video Expert? Answer questions, earn points and help others
