Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
LOUD GRINDING NOISE ALL OF A SUDDEN , LOOSE BELT ?
ALL OF A SUDDEN MY dc07 STARTED MAKING A KIND OF GRINDING NOISE ALMOST LIKE THE BRUSH BAR IS WOBBELY NOISE IS WORSE WHEN IN CARPET MODE NOT ON REG FLOOR
  • 43 Answers
You will probably have a faulty roller bar take of panel on bottom of vaccum. Now remove the roller bar hold the bar by both ends and try spinning. This should be easy and smooth if not pull off the end cap these will be very tight and check the bearings in each end i think you will find a few small metal balls rolling around inside if this is the case you need to replace the bar
Posted on Nov 11, 2008
DC07 grinding noise
I had the same problem with mine, I took it to a repair shop. The problem is where the belt passes through from the brush and goes inside the machine. Move the belt over a bit and you will see that a plastic guide has been bent over and is pressing onto the brush, which causes the noise. Just bend it straight again and it stops.
Apr 21, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
DC07 dyson brush not turning
Hi Robin,
I'm sorry to hear you're having difficulties with your DC07. Your machine's brush control is designed to make a ratcheting sound to warn you if an obstruction is jamming the brushbar. The easiest way to check everything is correct with the machine is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=804&product=DC07-ANIMAL_US
This should resolve the issue, but if the cleaner continues to make the noise after you've removed any obstructions from the cleaner head, please call us free on 0800 298 0298 (UK), or 1866MYDYSON (US), so we can help.
Kind regards,
Jack
Dyson Online Customer Support
Nov 21, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Burning smell loud grinding noise when tilted
Hi there SmartAlec from NelsonVacuums.com.au here. The rattle is the clutch engaging. It can happen for a couple of reasons. The best case for you is if there is something caught in the brush roller that you can simply remove. The next best is that the end caps of the brush are full of junk that you will be able to remove. Its not easy getting the brush out to clean there but it can be done.
If the brush spins in your hand easily when the brush is removed then it is the clutch itself. THe main roller often melts which is caused when the tension on the belt gets to high thus creating too much heat. THis can be resolved only with a new clutch.
Hope this helps, if you have more questions dont hesitate to reply or if you need parts just visit
NelsonVacuums.com.au.
Happy Vacuuming :)
Apr 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loud noise coming from DC07
Sometimes the brush bar may be slightly bent and has been rubbing against the yellow housing part (at the hole where the belt is) and has melted part of it off, the part which holds the brushes in place. The noise may the bar vibrating against the yellow part because they are now loose. Unfortunately you may have to replace both parts.
Feb 05, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Dec 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
When I tilt back handel and turn dial to carpet It makes a loud grinding noise
On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
Jul 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loud Grinding Noise
Take out the brush block and see if it will power on, if not then probably your motor has gone bad.
Feb 04, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
503 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
