Question about Galaxy External Enclosure - Metal Gear Box II - 3.5in USB 2.0 + 1394 Hard Drive (3506UEP) Drive Case
Galaxy Hard Drive fails to start
Galaxy metal gear box external hard drive fails to start. it has power, but it keeps starting and them making a noise of shutting down, and it repeats itself: trying to boot, and then shutting itself down.
  • ringo_s Feb 25, 2009
    2nd one i have that has failed in the last 3 months. Both approximately 1-1.5 years old. Issue with the controllers going bad. Can that happen?
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My computer wont show my hard drive when its plugged in
have you tried connecting the hardrive to some other computer. Is it getting detected on it?
May 30, 2011 | Galaxy Microsystems Galaxy METAL GEAR...
I have a Galaxy Metal Gear Box. It will house two hard drives. It refuses to post the second drive. I just put a brand new one in it. Same result. Rocky
If both drives are SATA (not "parallel-ATA") drives, then "swap" the physical location of the two drives, to see if only the "top" (or the "bottom") drive is NEVER detected. Or, if the "detected" drive moves after the drives are swapped, then the non-detected drive has a problem. In that case, remove the "good" drive, to see if the "bad" drive can be detected when it is the only active drive.
Jan 11, 2011 | Galaxy Metal Gear GMG 3538UCBLK 35 Dual...
My Metal Gear Box external hard drive has a flashing blue light, and my computer does not detect the external hard drive, what is the problem?
the weird cheap power supply they used has failed. I will never buy another galaxy product. This whole time I thought the hard drive crashed, but it was the enclosure all along that died at about a year.
Nov 14, 2010 | Galaxy External Enclosure - Metal Gear Box...
My external hard drive is not being recognized by my computer.
Try using another USB cable or different port on your PC. It also may be that it needs external power, Check to see if its plugged in to the wall, if it is, it may be that you need a new power supply.
Jun 03, 2010 | Galaxy Metal Gear GMG 2518UAS External...
Gear's wont change into 3rd 4th gear and has high revs
Take your external to your local car dealer and have them reformat the gearbox lmao!
Dec 17, 2009 | Galaxy External Enclosure - Metal Gear Box...
I went to best buy and bought a new HDD after they told me it was bad. I put it back into the metal gear box and it just kind of clicks and when i connect to computer it doesn't see it. suggestions??
I want to say this kindly ... do yo know what you are doing? You can't just change the hard drive ... there are many steps to changing the drive to make it work ... like assuring it is the master drive ... like formatting ... like installing an operating system, if appropriate.
Now that they sold you the drive (who is to say your old drive was faulty?????) they will fix it for you for a new fee.
Nov 01, 2009 | Galaxy External Enclosure - Metal Gear Box...
Need user name and PW for web interface
Go here for the manufacturer product page, and a link to the pdf manual for it. The starting User Name and Password are on the first page of that manual.
Nov 08, 2007 | Galaxy External Enclosure - Metal Gear Box...
Metal gear enclosure 3.5 box 2
Sounds like you haven't formatted the external Hard-Drive.
You need to allocate a file-system to the free space on your hard drive. You can do that in Disk Management and use the format option. You can select from two file system formats: FAT32 and NTFS. I would recommend NTFS because it is a journalling file system (recovers quickly in case of a crash).
Oct 20, 2007 | Galaxy External Enclosure - Metal Gear Box...
Galaxy External Enclosure - Metal Gear Box II - 3.5in USB 2.0 + 1394 Hard Drive (3506UEP) Drive Case Logo
372 people viewed this question
Top Galaxy Computers & Internet Experts
Chance Miller
NOEL
NOEL
Brian Anderson
Are you a Galaxy Computer and Internet Expert? Answer questions, earn points and help others
