Question about IBM ThinkPad T23 2647 Notebook
I have forget the Bios password on my T23
When i turn on the computer i need to enter 4 digit number to load the win
I belive it is the Bios password.
Thanks for your help
  • 1 more comment
  • Anonymous Jan 08, 2009
    i have ibmt23 laptop. i forgot the bios password and don't know how to reset it. please help me reset it.
    email address is aindardat@yahoo.com
    please help.
  • Anonymous Feb 13, 2009
    TURN UNIT ON AND I GET PADLOCK ASKING FOR A PASSWORD MY KIDS DID NOT LET IT POWER DOWN BEFORE CLOSING IT
  • Anonymous Mar 02, 2009
    I have the same problem I know my password but the laptop will not except it I tried removeing the batteries that did not work please help me if you can Thank's daniel
Bl r 1935
Posted on Dec 03, 2008
  • 837 Answers
If its the BIOS/CMOS battery .. you are pretty much unless you want to do 1 of the 2.
1) Open it up and remove CMOS batter
2) Or go here
Posted on Dec 01, 2008
Dell dimension 3100 win xp home will not logon or go to setup/boot screen, only goes staight to black screen saying TYPE SYSTEM PASSWORD AND PRESS [ENTER] but it doesn't let you type anything. Also will...
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
Oct 20, 2013 | Dell Dimension Computers & Internet
I cant remember my login password and f8 does not work in safe mode still asking the password
Once you assign a password to your HP computer's BIOS configuration utility, you will need to enter that password every time you attempt to access the BIOS.
If you forget this password, don't fret there is still a way to unlock your BIOS without actually knowing the original user defined password.
This involves using a "backdoor" password, which is something that is installed onto your BIOS at the factory level that never changes.
Turn on your HP computer.
Press "F2" to load your HP BIOS access screen.
A password prompt will load on your monitor.
Type "merlin" into the password field (with no quotes) and hit your "Enter" keyboard key to unlock your HP BIOS password.
Sep 20, 2013 | HEWLETT-PACKARD Computers & Internet
Bypass bios setup password hp pavillion
Step 1:
All computer BIOS chips have a backdoor master password designed to be used in the event that you can't remember the password you set yourself or by a tech support agent who is fixing your machine. These passwords are set at the factory level and do not change, no matter what model of computer you own. You will use this password to bypass the currently set password in the event that you need to access your HP BIOS but cannot.
Turn on your HP computer. Strike the "F2" keyboard key. Your HP computer will attempt to load your BIOS. You will be prompted to enter your current password. Type "merlin" into the password prompt and hit "Enter." This is the backdoor BIOS password for HP brand computers. You will now bypass the user defined password and the BIOS screen will load as normal.
How to Reset a BIOS Password
http://www.tech-faq.com/reset-bios-password.html
Mar 11, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
I am forget my bios password on my laptop ibm think pad t23 , i put 3 ways password (pop, hdp,svp) how can i fix it please :(
in the password place type administrater some times that over rides youre pass word and you can try running in safe mode and then you can delete youre password you forgot hope this helps
Jan 27, 2012 | IBM ThinkPad T23 2647 Notebook
Remove toshiba password from bios satellite 3000-x4
The Basic Input/Output System (BIOS) password is not set by default on Toshiba laptops. When set, the BIOS password must be entered every time you turn on your Toshiba or wake your system from Standby mode. If you forget the password, you cannot boot your system. Prevent having to enter a password or the results of forgetting the password by removing the BIOS password from your Toshiba laptop. Other types of passwords can be set, such as a Windows password, to prevent unauthorized access to your machine.
1. Turn off your Toshiba laptop.
2. Wait 30 seconds and turn your laptop back on.
3. Press "F2" repeatedly as soon your Toshiba laptop begins booting until the BIOS menu screen appears.
4. Enter your existing BIOS password and press "Enter."
5. Press "F2" again to enter the BIOS, if prompted.
6. Use your arrow keys to select the "Security" tab in the BIOS menu.
7. Use the arrow keys to select "Set User Password."
8. Press either "F5" or "F6," depending on your Toshiba laptop model, to open the Password section.
9. Enter the current password into the "Old Password" prompt and press "Enter."
10. Press "Enter" when the "New Password" prompt appears. Do not enter any text in this box.
11. Press "Enter" again to confirm the new password.
12. Press "F10" to save your changes and exit.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Computers & Internet
After boot, appears ENTER PRIMARY MASTER HDD USER Password i need the password @ solution to boot up my lappy... thanks
How Do I Change the Primary Master HDD User Password?
Prior to loading an operating system, your computer will first execute the BIOS program. The BIOS has an extra password feature, called the hard disk drive (HDD) user password, that can't be bypassed and provides a layer of defense to keep your data secure. To change an existing HDD user password you will have to load the BIOS menu, which is only accessible during the computer's operating system reboot procedure.
Instructions
1. Close any windows that are currently open on your computer. Eject any discs inserted into the optical drive and disconnect any peripheral USB devices.
2. Open the "Start" menu and select "Shut Down." Turn on your computer once the operating system finishes shutting down.
3. Press the key your computer uses to load the BIOS menu. For example, with Dell computers tap "F2" when the "Press F2 for Setup" option appears. Press the "Access IBM" key on IBM laptops or "F10" on HP desktops.
4. Navigate to the BIOS tab that contains the HDD password option, which will usually be the "Security" tab. Some computer manufactures instead include the password option in the "Advanced" tab.
5. Scroll down to the option labeled either "User Password" or "BIOS lock" and hit "Enter." Type the current master HDD user password when the prompt appears and press "Enter."
6. Input a new HDD user password and hit "Enter" again. Navigate to the BIOS tab labeled "Exit" or something similar.
7. Move over to the "Save and Exit" entry and press "Enter." Select "Yes" and tap "Enter."
Nov 15, 2010 | Acer Aspire 5610 Notebook
Fujitsu Siemens AMILO Pro V2000 PC Notebook what default BIOS password My computer is locked
there is no default bios password
all i know at the some fujitsu laptops if you enter 3 times wrong bios password the computer locks
This is a security issue
Jul 09, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Lol
Ok, great an good for you!
I thought about that administrator rights but I suppose that you were the administrator instead a user.
But this things happen. I'm glad to know that you finally you found a solution for your issue.
Anyways, if you need further help please let me know.
Have a great day!
Please don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
Acer 3089
hmm which password ??? is it the bios password or the windows password.. Any way I will give you solutions for both
THE BIOS PASSWORD
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
TO RESET WINDOWS PASSWORD
1.) dowload hirens boot cd from here
www.phazeddl.com
you will need to search hirens when you go to the site
2.)burn off cd
3.) boot from cd
4.) use the on screen menu to fine windows password reset tools,
5.) choose the appiorate one and follow instructions to change or reset password..
THATS IT WINDOWS PASSWORD RESET..
let me know if you need any more help good luck
Jan 10, 2008 | Acer Aspire L100 PC Desktop
Power-on password problem!
The power on password is stored on an EEPROM chip and removing the BIOS/CMOS battery won't help.
You need to read the EEPROM chip to get the password.
GOTO
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
for solution to your problem (you need to construct an interface hardware and install two programs on a working computer)
Have fun
ChrisH
Dec 28, 2007 | IBM ThinkPad T23 2647 Notebook
IBM ThinkPad T23 2647 Notebook Logo
196 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
