Question about EliteGroup RS482-M754 Motherboard
Error Message on 1st page boot up
Error Message Reads: Warning CPU Freqency needs resetting in CMOS
page describes my CPU as AMD Athlon 3500+
Having looked in the BIOS the Frequency is set at Startup I have tried resetting to 2200 but this makes no difference as I still get the same error message.
Help
Chris
    President:
  • 2,351 Answers
Hi Chris,
Reset the bios jumper on the board. Use your manual, go to the bottom of page 9. Please unplug the power cord from the PC.
Clear the cmos/ bios & remove the bios battery as well. (You may use a small flat tip screw driver to help lift the battery out). If you have a voltage meter check the battery for 3volts DC. (If you have a voltage meter suggest you check the battery for 3volts DC while its out).
Re-place the bios battery & reset the bios jumper back to Normal. Re-connect the power cord to the PC. Boot the system & enter the bios menu. Adjust all your setting as needed.
(DO Not over-clock anything)!
If you still receive an error message your only other option would be to flash the bios. Even if you have the latest bios software already installed. The current bios software may be corrupt.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=537&CategoryID=1&DetailName=Bios&MenuID=48&LanID=0
Good luck Chris!
Mike
Posted on Nov 08, 2008
I have an acer aspire ast180-340b, I upgraded the cpu from Sempron to AMD Athlon 64 x2 3800+ but the computer keep saying I need to clear cmos. How do I clear cmos on this computer ?
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya Van Pham.
I have published a guide that deals with this very topic, it is entitled How do I reset my BIOS/CMOS to defaults?
You also may want to see the following guide entitled, How to Remove the Side Panels of My Computer Chassis!!!
Basically you will need to remove the CMOS battery found on the mainboard for a few seconds and then reinsert it again.
Take care!
Nov 01, 2011 | Acer Aspire (AST180-US340B) PC Desktop
Can you tell me why when i put CPU in my computer he give error? CPU is AMD Athlon 64 3400+ 2.4GHz socket 754.My motherboard is socket 754 Gigabyte GA-K8NE-RH. Problem is my computer or CPU?I take CPU...
The motherboard will support this CPU, with the F1 bios.
I can only advise, that IF your motherboard was working ok before you put the new CPU in, it must be the new cpu you bought.
If this is the 1st CPU you have tried, there is a chance the board is damaged
Jun 13, 2011 | AMD Athlon 64 3400+, 2.4 GHz...
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
Powers up and cpu fan is racing but no boot,
This may be due to a CMOS mother board battery. I know that some tech or expert say that you can still boot without it but my experience is that if the CMOS battery is below 3.4 volts it may or may not post or boot. This battery is about the size of a quarter usually found at Walgreens or Walmart for about 3.00 dollars.
Apr 06, 2010 | HP Compaq Presario SR2020NX PC Desktop
Just installed new mobo (ecs 6100sm-m) and boot up issue
from my experience, you will need to format when changing the hardware you have changed. are there files on the drive that you need? if so id recommend putting your old motherboard back in to backup the drive then rebuild and format. thats if it wasnt faulty to start off with.
hope it helps
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
BIOS error - CPU is unworkable or has been changed
try to reset cmos by removing CMOS battery from motherboard and reinsert again...
Dec 12, 2008 | Abit KV7-V Motherboard
Can not upgade memory from 2G to 4G
have you checked the frequency of the new ram you are using if its not of the same type and of same frequency as of the another one your system wont boot
Sep 14, 2008 | Acer Aspire™ T180 PC Desktop
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
New cpu but no video output
I SEE YOU MENTIONED NOTHING ABOUT INSTALLING ANY DRIVERS FOR THE HD'S DID YOU?
GOOD DAY
KZ
Feb 28, 2008 | Intel Motherboard
ASUS A*S-X not recognizing cpu
you should be able to press F2 or Del on boot up to get into the bios, but you should replace the battery first then set everything up as the cmos has obviously lost it's saved settings because the battery is flat.
Sep 10, 2007 | ASUS A8S-X Motherboard
EliteGroup RS482-M754 Motherboard Logo
93 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
