Question about Cameras
Canon power shot a85 digital camera, showing error number 18
  • sarena Nov 06, 2008
    didn't work.
  • sarena Nov 09, 2008
    This didn't work either.
    Sergeant:
  • 207 Answers
This is listed as a Camera LENS problem.
and can occur for one or several of the following situations
Camera activating and lens opening while in a confined space
Extracted lens getting jarred
Low battery condition as the unit is turned on or off
Dropping of the camera
Foreign substances, such as dust, sand or dirt entering into the camera body.
General jarring of the camera
General camera malfunction
Recommend solutions I've found are
1. Remove the batteries and activate the power switch with the batteries out for 5 seconds, reinstall batteries and try to use camera.
2. try connecting camera to TV / PC and see if that improves things
3. If the lens is visibly ajar you can try manipulating it manually BUT this usually requires the attention of a professional service tech
Hope this helps you
Dave
Posted on Nov 09, 2008
    Sergeant:
    Novelist:
  • 196 Answers
TRY THIS OPTIONS 1 BY 1 .ONE OF THEM WILL HELP YOU.
1)tap the camera on the usb side a few times.
2)OFF the camera remove  the CF card and  turn the camera back on. Once it powered up, the lens retracted and the camera works normally again. 3)just replace the old batteries sometimes it get used quickly due to some reason. 4)open the bottom and back screw, the helicoil which is locked, just  release that ….and the camera is back to normal. Do not disassemble the whole camera, just move the case below the lens slightly.and it will automatically get adjusted.
Posted on Nov 06, 2008
    President:
  • 2,712 Answers
This is the solution offered by the Canon website:
"The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.
Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred. In this case, you will need to get the camera serviced."
Basically, it looks like the lens is stuck or obstructed. Try twisting the lens gently or pull it out gently to see if this helps. Tapping the camera gently on the palm of your hand has also been known to be helpful in dislodging stuck lens..
You can contact Canon at 1-800-828-4040.
  • Cameras Master
  • 6,487 Answers
The cylinder barel sensor is malfunctioning and it needs a repalcement already if its still under warranty better take it to a service center or have it replace...
  • Cameras Master
  • 19,396 Answers
E18 is lens error, tell me if the lens are extending and retracting normally when you turn the camera on and off.
  • Ginko
    Ginko Nov 06, 2008
    E18 is lens error.
    First remove the batteries and see if this clears the error message.
    If the lens do not extend, try slapping gently the back of the camera, and also using you fingernail to help lens out while you turn the camera on.
    If lens do not retract, try pushing them gently inside when you turn off the camera.
    If that cannot solve the problem, then the lens assembly must be taken apart, cleaned , lubricated and remounted , this job must be done by a technician unless you want to transform your camera in a bunch of bits and screw.
    If you need to send the camera for repairs, then you can call the phone number listed on the camera user manual.
  • Ginko
    Ginko Nov 06, 2008
    Did you do all this already?
    I re-post, probably you did not get my comment:
    E18 is lens error.
    If
    If
    and screw.
    President:
  • 624 Answers
Take out the batteries for about 20 minutes, then put new batteries in and see if it works right.
  • Cameras Master
  • 1,879 Answers
Remove memory card, batteries then use canned air.
A85 camera LCD shows up with pink and black lines every time a picture is taken. LCD screen displays the camera icons on LCD screen but will not take anymore photo's. Lens used to view picture status...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 06, 2010 | Canon PowerShot A85 Digital Camera
Lcd screen flickers in photo mode
If your Canon A85 shows distorted image in live view (camera mode) then its known problem of ccd imager chip failure. Check below image.
canon offers free of cost ccd imager chip replacement in A85 model.
Please confirm if its canon A85 camera or any other model to provide you more info.
Dec 23, 2009 | Canon PowerShot A85 Digital Camera
Canon PShot A85 - blank screen with a flickering purple backgr
Definitely sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 16, 2009 | Canon PowerShot A75 Digital Camera
Canon power shot A85
Your CCD may be broken or become disconnected. If this is the problem Canon will repair your camera free of charge and pay for shipping both ways. Contact Canon customer service to arrange the repair.
Aug 08, 2008 | Canon PowerShot A85 Digital Camera
Canon Power Shot A85 digital camera
See this link. This service notice applies worldwide, so if you don't live in the US, contact your regional Canon service agency. They should repair your camera at no charge, regardless of warranty status.
Jul 27, 2008 | Canon PowerShot A85 Digital Camera
Canon Power Shot A75
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
May 27, 2008 | Canon PowerShot A85 Digital Camera
This sounds like it might be a defective CCD imager. The good news is that Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Dec 24, 2007 | Canon PowerShot A85 Digital Camera
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
