Question about Fuji FinePix A350 Digital Camera
Zoom error how do i fix
  • 244 Answers
See my solution for fuji A345 zoom error. Same lens
Posted on Jan 28, 2009
the spare parts won't be so much, if you try and fix it yourself, you will save a ton of money otherwise it could be around $100 to send it in and get it fixed. You can start finding the problem by opening the screws on the bottom/back of the camera and find what gears are jammed and won't zoom. or I can get you a number to call to send it in, thanks
Let me know what you want to do
Apr 04, 2008 | Olympus SP-550 UZ Digital Camera
Display shows "Zoom Error".
In this link can find details about everything you can try to fix it without sending it to a repair shop: Fixing-lens-error-on-digital-camera
Hope helps (remember to rate and comment this answer).
Mar 31, 2011 | Fuji FinePix S304 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
I fixed the first problem..!
I fixed the "zoom error" problem..but to be honest I'm not exactly sure how..i found some "jewelers tools" and following instructions found on this sight,ever so carefully,started unscrewing screws.First I removed the lens shroud,made sure it was clean...nothing..still had zoom error so then proceeded to remove the back of the camera..looked around and kinda "shook" it out.There was one little screw left that was preventing me from getting to the gear box but it wouldnt budge and i was afraid of stripping the screw so I said heck with it and reassembled it..figured what the heck and turned it on OMG! imagine my thrill when the lens zoomed in and out just like it is supposed to! But then i inserted memory card,turned it on and got the "zoom error"message again followed by "no card". Now what?
Apr 13, 2009 | Fuji FinePix S304 Digital Camera
'zoom error' on olympus sp-560 uz
I had this problem and managed to fix it. The camera was dropped on a stone floor and the zoom error was present every time it was turned on. A ring or other piece of the lens was bent or damaged, in my non professional opinion. A profesional repair is my advice. However you may try my fix at YOUR OWN RISK.
Switch camera on, when zoom extends, but before it closes down due to zoom error, gently but firmly push lens back in. Drop batteries for camera to reset itself. Repeat, if necessary.
My camera now operates fully and when the lens extends it now no longer makes the slight grinding noise.
Good luck and remember at your own risk.
Jul 30, 2008 | Cameras
Zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Fuji FinePix S7000 Digital... Problem: Zoom Error
The manual describes all warnings the camera displays. Check the manual or go here for the manual online in pdf format.
Dec 13, 2007 | Fuji FinePix S7000 Digital Camera
Zoom error
No solution repair probably as expensive a replacement Contact Fuji the do a swap out at a discount service
Jun 23, 2007 | Fuji FinePix A360 Digital Camera
Fuji FinePix A350 Digital Camera Logo
274 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
