Question about Brother IntelliFax-2820 Laser Fax
Change drum sign
How did ya fix it?...this is happening to mine.
  • JennaF Nov 13, 2008
    We have already replaced the drum, and the fax continues to say "Change Drum Soon".
    Genius:
  • 2,120 Answers
Replace the drum.
Posted on Nov 11, 2008
Recalls issues
recalls are current until the recall is effected and signed of by the workshop
Oct 20, 2015 | 2005 Chevrolet Malibu
How do I disable the security system on a 2000 gmc sierra4x4 , 4.3 liter, auto
You cant disable it.. ive had this happen to me.. the security system has failed.. there is a way u can fix it,, I did some research and thisis how I fixed mine.. my family is on a budget and this is very reasonable .. hope this helps ya
Oct 17, 2014 | 2000 GMC New Sierra 1500
How do i change the time and date?
Thanks for taking time to ask us at Fix Ya. This solution applies to alcatel OT800.
1. Go to your main menu.
2. Select on the clock sign.
3. You can set your local city if listed if not just select a city your time corresponds with.
4. Select set time
5. Enter the time
6. Select either am/pm
7. You could also set the date
8.Also could apply daylight saving.
9. Select to go back
10. You can also change the format to either 24 hr or 12hr clock.
Thanks for asking at Fix Ya where we provide solutions
Feb 17, 2011 | Alcatel Cell Phones
I have a Canon iR1024A that is leaving black streaks down side of paper... I have changed the toner.. cleaned out where the toner goes... and changed the drum... nothing changed.. can you help me
If you have changed the drum then probably your fixing film was torn. Check if the black streaks on paper is erasable (not fixed on the paper). Check also for signs of film (gray on one side and brown on the other very thin plastic-like material) falling out from your fixing assembly (if you open the left side cover with caution sign the hot portion area).
Sep 22, 2010 | Canon ImageRUNNER 1670F Copier
Smok coming out of inside when we oped the door on
heater thermostat could be stuck on are the clothes warm after rinse?
Mar 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a 92 Town & Country Minivan that will not start at all... If you put it in park nothing happens but if you put it in neutral it sounds like it wants to turn over and start but doesn't. I have...
CHANGE THE NEUTRAL SAFETY SWITCH AND THE PROBLEM SHOULD BE SOLVED. THE FIRST SIGN OF THE NEUTRAL SAFETY SWITCH GOING BAD IS NOT STARTING IN PARK. KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
May 09, 2009 | 1992 Chrysler Town & Country
Change drum sign
open the front door, you will see the toner cart and the drum pull out the drum unit to you, good luck
Dec 22, 2008 | Brother IntelliFax-2820 Laser Fax
Baffles
These are the paddle bits that are inside the drum? If so I had the same problem and I found that the lugs that hold them to the drum were broken.
I fixed mine by using plastic cable ties (=tie-wraps) passed through the slots in the paddles and through holes in the inner drum. It's fiddly getting the ends back out of the space between the outer and inner drums - I used another tie-wrap bent into a loop and stuffed into a suitable hole to "catch" the end of the tie I was fitting. It's not a pretty solution but it works and it is almost free!
If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Thanks, D
Jul 13, 2008 | EuroTech EWF172 Front Load Washer
Garmin c310
Hiya... I had a similar problem and managed to fix it as follows. With the unit switched off, plug in the usb/pc cable and hold down the "on" button until the screen reads pre boot mode. Keep on holding down the "on" button and reinstall the updater software from the Garmin site. When completed release the "on" on button and hopefully the unit should re boot normally. Hope this helps. Cheers Lishmann
Mar 21, 2007 | Garmin StreetPilot c310 GPS Receiver
Brother IntelliFax-2820 Laser Fax Logo
70 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
