Question about Maytag MGR5770 Gas Kitchen Range
Display reads "OFF" Maytag MGR5770
I had to work on some electrical ckts in the kitchen today, so turned the power off and the breaker box. When I turned to power bakk on the Stove's Oven won't work. can't set time or anything. Stove has power to it since the oven light works. Manual doesn't say anything about a display of OFF.
Thanks in advance
  • HONDA399 Jan 21, 2009
    i have the same prob changed some elec boxes and power was off when i
    turned it back on it wont give the time or oven wont work
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Maytag MGR5770 Gas Kitchen Range displays OFF and nothing works!
That is normal, whenever you cut power the range goes in Off mode, that is a safety standby mode. The same as you first installed the kitchen.
No faulty thing and no need to take apart anything, do not disassemble the appliance.
The usual procedure to activate back the kitchen range is by downpressing the timer main wheel.
If this does not work, then there must be a different command, check the user instructions , or try playing withthe controls.
Posted on Nov 07, 2008
I have a Maytage electric slide in range with a ceran top. Model number MES5770ACW. I was cooking dinner last night on my stove and the elements on top stopped working. They will not turn on at all even...
Either control board bad, or there is more then one circuit breaker controlling the power, check the breakers on both the inside and outside breaker box...Stranger things have happened..
Sep 10, 2017 | Maytag MES5770 Electric Kitchen Range
Admiral wont heat
Your breaker in the breaker box has a double pole breaker for the stove one breaker is shot so you still have 120volts which runs the lights 240volts for the elements.Turn main power off and replace the breaker. To verify for sure pull the stove out and unplug it check power at the plug you need 240volts at the plug. If i dont have a plug and wired straight in disconnect the wires and check the wires.
Sep 01, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Panel off
Try cutting the power off to the unit for 10 minutes. most of the time this will reset the clock and it will work fine. if not replace the clock.
Nov 20, 2008 | Maytag MGR5770 Gas Kitchen Range
Fuses can become weak, burn out or blow out.
Check for fuses and test them for continuity.
Nov 07, 2008 | Maytag MGR5770 Gas Kitchen Range
Display Malfunction
Hello murfraven,
Welcome,
You said, you went to set the timer while baking a pizza and I got a "set or en" on the display of my Maytag Gemini Ceramic Top electric oven.
How old is the range?
And the model number?
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the switch itself is bad.
Let me know how it works out.
Huuum, Please remember to leave a rating
Oct 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
MANUEL
baking system-not lighting up.Code f-9 did show up.broiler works.Please advise
Sep 15, 2008 | Maytag MGR5770 Gas Kitchen Range
MEW 5530
Possible damaged control panel.
Jul 28, 2017 | Maytag MER5530 Electric Kitchen Range
Maytag electric range will not work
you have a house power promblem turn off the range at the breakers and start at where the cord connects to the range check it there then go back to the breakers all the eyes are on their circutes so it has to be at the power source feeding them
Jul 14, 2008 | Kitchen Ranges
Clock display/oven control panel
a few screws will drop rear panel to check connections, , check your power supply as wellpossible bad connection at outlet
Feb 25, 2008 | Maytag MGR5770 Gas Kitchen Range
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Maytag MGR5770 Gas Kitchen Range Logo
97 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
