Question about Sony CMT-HP7 CD Shelf System
Sony cmt hp7
I have the same problem i think the voice coil got shorted inside how i fix it ?
  • Sony Master
  • 5,568 Answers
Wow! What a stale message.
Speaker voice coil alignment is critical enough that it requires special skills to replace these and with the price of replacement speakers being pretty minimal, I wouldn't even recommend it. If the enclosure is not welded shut, I would open it, determine the diameter and take notes on any specs printed on the frame (such as '8 ohms') and buy TWO them from any of thousands of vendors (start with eBay).
There are very high power speakers for stage use that cost hundreds of dollars to replace and these can be repaired by specialists economically.
Posted on Mar 17, 2009
My Sony CMT-HP7 will not play any of my CDs. It says reading for a long time and then tells me that there is no CD and skips to the next CD... which it don't recognize.
Usually deleting the Upper and Lower Filters in the Registry resolves this issue. To do that follow this.
1. Run Regedit
2. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
3. Delete Upper and Lower Filters on the right hand side pane.
4. Exit and restart.
Please comment if the information has been helpful. Thank you and regards.
Aug 26, 2010 | Sony CMT-HP7 CD Shelf System
Prestting the stations
All of the presets I have encountered in the last years were thankfully simple; you manually tuned the station, then simply pressed and held the desired button until the display was stable (not blinking).
Mar 17, 2009 | Sony CMT-HP7 CD Shelf System
Sony cmt-hp7 shelf system
they have some problem on the audio amplifier IC maybe are damaged
Oct 09, 2008 | Sony CMT-HP7 CD Shelf System
Remote for the CMT-HP7
The remote control for model number Sony CMT-HP7 can be found in the link below.
Sony CMT-HP7 Replacement Remote
Apr 16, 2008 | Sony CMT-HP7 CD Shelf System
Sony cmt-hp7 - broken
The unit will attempt an internal reset to start from a known position. If you are hearing mechanical noises, the unit is out of sequence and must be rebuilt. These are not the most straightforward units. If any portion of hte system fails the "startup" sequence, the entire unit will stop. Unfortunately, this may need to see a servicer.
Dan
Mar 21, 2008 | Sony CMT-HP7 CD Shelf System
System cuts off 4 seconds after power on
hi, be careful, check ur speaker connection , its getting short somewhere, remove all the speaker cables and then check if the problem is still there, sometimes the speaker voice coil also gets shorted inside let me know
Dec 30, 2007 | Sony CMT-HP7 CD Shelf System
Shelf cds is blocked SONY CMT-HP7
To get the cds to play, and 5 to eject, you can try taking off the sides of the consul and using compressed air. As for the shelf problem, I'm not really sure.
Nov 09, 2007 | Sony CMT-HP7 CD Shelf System
Sony CMT-HP7 CD Shelf System Logo
164 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
