Question about Southwestern Bell Landmark DKS930 Corded Phone (swblandks930)
Need manual for setting up swb landmark dks 930 phone
We are using a phone system that was already set up in our office. We have the swb landmark dks 930 phone and do not know how to program or set it up. We need to be able to set up time/date and the answering system.
Please help...I tried to find free manuals on line with no luck
F#*000000 IS THE PROGRAMMING ACCESS FOR THE LANDMARK. YOUR SHIFT KEY ON THE PHONE IS ACTS AS THE BACK KEY, TOP OF MENU KEY. ONCE YOU GET INTO PROGRAMMING, GO TO RESOURCE MENU HIT SHOW, THEN NEXT TILL SYSTEM TIME APPEAR, HIT SHOW, THEN CHANGE TO ENTER TIME. USE THE DISPLAY WINDOW TO HELP YOU .
freddy@lumbrefutbol.com
Posted on Jan 08, 2009
  • 32 Answers
In order to enter programming mode, on any set, while the handset is cradled:
Dial: Feature, #, *, 000000 If the password has been changed you will need to know the current password. If you can't get the password, you can reset the system to it's factory default programming. I can't remember exactly where, but somewhere on the ksu there is a button you can press to load the defaults. Also, if the system is old, the ram battery is probably no good and in that case, simply unplugging the ksu and then plugging it back in will do the same.
Once in the programming mode, you can explore and change the many options for the system and stations. It is very easy to understand.
NOTE: When the default programming instructions are loaded, only station 10 (operator) will ring on incoming and numerous other annoying features change, such as the DTMF tone burst length.
Good Luck!
BB
Posted on Jan 05, 2009
I need a manual for a landmark dsx 308xl telephone system
Try Googling (landmark)(dsx 308xl)(manual) without parens.
Aug 29, 2017 | Lands Phones
Phone number for Kapersky Melbourne office
phone Victoria and ask. The Melbourne office is secret according to an article from 2008.
Kaspersky Lab
Address: 1/82 Lorimer St, Docklands VIC 3008, Australia
Phone: +61 1300 930 655 Hours: Open today · 8AM-6PM
https://www.kaspersky.com.au/about/contact
Mar 30, 2017 | Computers & Internet
How do I get a dial tone.can answer the phone.just cannot dial out
I am NOT familiar with YOUR make and model of phone, BUT.... I've had several cordless phone systems over many years, and have had the same problem that you describe. First, here is some background info for you:
The telephone company systems USUALLY have two different dialing systems:
  1. The "old" ROTARY DIALS worked by MECHANICALLY sending out different numbers of electrical pulses which the MECHANICAL "receivers" at the phone company "Central Office" buildings would read and thus connect you to the dialed number.
  2. Some years ago, a "new" dialing system was initiated. That system was called Dual-Tone-Multi-Frequency [or for short, DTMF].
DTMF uses BUTTON KEYS which put out a different electronically generated TONE [related to] for each different NUMBER key pushed, and THAT series of tones told/tells the phone company Central Office receiver computer the number to which you wanted to be connected.
Around the world over the years, most phone companies have, and still use one of these two dialing systems, AND...
Most cordless phone manufacturers designed their phones to work WITH EITHER system, BUT....
The customer IS REQUIRED to "SELECT" which system his phone company uses, while the customer is "SETTING UP" his/her new cordless phone.
THAT process IS INCLUDED in ALL cordless phone set-up instruction packages I've ever seen!!!!!!
Either you need to carefully read and study YOUR installation-set-up instructions and then PROPERLY set your phone's dialing system [to PULSE or DTMF], OR GET SOMEONE who KNOWS WHAT he, or she is doing to do it for you.
I, and I think no one else is able to guide you via back and forth messaging on this site. At least I know I can't because I'm not acquainted with your cordless phone, AND I don't have an instruction/set-up manual to consult!!!!!
Track down your manual, OR search for a replacement manual; the dialer system selection process is NOT DIFFICULT IF you have the manual!!!!!!!
Nov 25, 2014 | Vtech CS6649 - Multi Handset Phone System
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
Internet connectivity manual settings required for Airtel GPRS / Mobile Office
Hello Friends
iam Ilyas Ali From Bharti Airtel Prepaid Raipur Zone
For Activation Mobile Office Please SMS Type MOA(space) To 52818
For Activation Net On Phone Please SMS Type NPA (space) To 52818
Mobile Office-After Activation Get Setting by SMS Type MO To 52567
Net On Phone - Get setting SMS Type NOP To 2567
Chaina Mobile Setting
Many of us think it is not actually possible to surf on China Mobiles after hearing negative answers from those peoples but the real thing is that we can surf. Follow the easy-to-learn steps to use Mobile Office on your Piece.
Steps :
1. Goto the Main Menu | Select DATA ACCOUNT | GPRS | EDIT
ANY EXISTING ACCOUNT
2. Account Name ==> Dark Core
APN ==> airtelgprs.com
Auth. Type ==> Normal
3. Save the Settings
4. Come back to SERVICES | WAP | SETTINGS | EDIT PROFILE | EDIT ANY EXISTING ACCOUNT
Rename Profile => Mobile Office
Homepage => wap.google.com
Data Account => Dark Core (which we created previously)
Connection Type =>
Here u find three option
a) Connection-oriented
b) Connectionless
c) HTTP
Choose ==>
IP Address ==> 202.056.231.117
Security ==> Off
Again save all the settings and click BACK button and choose
Activate Profile
Come back to SERVICES | WAP | Homepage
So, now you are ready to use Airtel Office..!!
If Any Problme Please Send Me Email - ilyasali55@yahoo.com
And My Contact No. +919981949877
Thanks&Regards
Iliyas Ali (19) M
Bharti Airtel Pvt. Lmt.
At Nsb Bpo solution Pvt. Lmt.
Apr 27, 2009 | ASUS Mypal A730W Windows Mobile 2003
I am In possession of South western Bell Freedom
Here is a direct link to all Southwestern Bell's products - Manuals - and Accessories!
http://www.swbfreedomphone.com
The phone number for their product support is
1-800-366-0937
they are open M-F 8:30AM - 9:00PM EST and
Sat 8:30AM - 12:30PM EST
Thanks
Len
Need more help? Just ask! We'll dig further!
Mar 08, 2009 | Southwestern Bell Lands Phones
No ring for some phones after power outage- dks 930 phones
Press feature key then dial #* password 000000 next, go to sets, hit show, hit next till ringing assingment is display hit show and change from n to y on line ringing assingment. do this for each set and line that need to ring.
Dec 24, 2008 | Southwestern Bell Landmark DKS930 Corded...
Call diverting
You need to know which phone system you have. Your phone can be used on different Panasonic phone systems that are set up differently.
Jan 10, 2008 | Panasonic KX-T7633 Corded Phone
Southwestern Bell Landmark DKS930 Corded Phone (swblandks930) Logo
1,066 people viewed this question
Top Southwestern Bell Lands Phones Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Southwestern Bell Lands Phone Expert? Answer questions, earn points and help others
