Question about Sanyo DVW-7100A DVD Player/VCR
Can't go above Channel 20 when input on Video.
I have a Toshiba LCD HD TV with the DVW-7100 DVD/VCR player. The remote will not work that came with the DVD/VCR player so I am using the Toshiba remote. I can't go above Channel 20 when I have the input on video even though I have done the scan several times and have no channels blocked. What do I do?
I was told by Sanyo and Toshiba that I will have to have a Sanyo remote in order to change the tuner from TV to CATV which he said is causing me to be unable to get above a certain channel and also to change the settings in order to use the Progressive scan cables, so I have emailed a remote finder site and they are trying to find a Sanyo remote for me.
Posted on Nov 10, 2008
Sanyo DVW 7200 PS2 won't work
Tune the DVD/VCR to "channel 3".
Dec 18, 2013 | Sanyo DVW-7200 DVD/VCR
Connect dvd/vcr to HD-tv via dish network
Hey my nameis Mike Houston of DISH Network and I see where you want to run the SanyoDVW-6000 DVD/VCR Player to the DISH Network receiver. You can run the SanyoDVD/VCR directly to the TV and pick the channel you want to record and it willrecord the channel showing.
Dec 07, 2010 | Sanyo DVW-6000 DVD Player/VCR
How do I get the VCR to play on the tv? It's a Sanyo DVW-7100 DVDPlayer/VCR Combo. The DVD will play but the VCR won't show up on the TV.
This maybe too simplistic but are you sure you have the right command buttons toggled try to set the player to VCR and not dvd.
Set the player to VCR with a tape in it and press play. I hope this works for you
Sep 29, 2010 | Sanyo DVW-5000 DVD Player/VCR
What channel does the tv need to be on to operate the dvd player? The dvd player comes on but it doesn't recognize the button commands on the tv-do no have the remote.
channel 3 or 4. if that doesnt work switch the input on the tv. the input button might be labelled input/source/tv-video or av. if you arent getting a pic while the dvd player is playing look at the back of the tv and see where the cable from the dvd player is going into the tv. it is labelled what input it should be on. ex: video 1, etc. hope this helps.
Jul 11, 2010 | Philips Magnavox 20MC4304 20 in....
I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
May 08, 2009 | Sanyo DVW-6100 DVD Player/VCR
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to set the time
Have you tried using the set up menu button on your remote? nanafromlv
Nov 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Televison & Video Logo
137 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
