Question about Whirlpool Dishwashers
Dishwasher flooding my 6 year old dishwasher suddely started to flood. I would assume there is a filter or similiar that is clogged? but the cover where this part is likely located is secured w/ unique "screws"...can you help?
  • 1,183 Answers
could you give us the model and maufacturer for the dishwasher to help you better.
Posted on Nov 06, 2008
  • Whirlpool Master
  • 19,396 Answers
Check first the drain hose, check also that machine is not overfilling and water is leaking out.
  • Ginko
    Ginko Nov 06, 2008
    Try to identify where the leaks come front:
    If the water level is normal and machine leaks from main door, then you will have to replace the main door gasket.
    If the leak is coming from underneath the machine, it is probably the main tub
    seal.
    This is located beneath the drain impeller, near the shaft of the motor, and it prevents the water in the
    dishwasher from leaking out .
    To access the tub seal you need to remove the spray arms , the lower panel, and the wash/drain impellers.
    Check also all the hoses and joints located behind the lower access panel on your dishwasher.
    If the machine is overfilling , and does not stop the water frow when at full level, check that the floating sensor connected to the water level switch is not stuck, and that the water level switch or the inlet valve are not defective.
    You can buy part here, and also get shematics..
    Here you get a general diagram and you can also buy parts.
What could make my 1993 geo tracker flood 1.6
the G16 engine, floods.
there are 2 engines, G16a and b.
8valve TBI and the 16v MPI engine.
(EFI on both are radically different.)
this pages shows all 3 levels of diagnosis
3 causes. physics.
14 causes.
and then the full list.
http://www.fixkick.com/flooding.html
to find the cause takes tools.
got tools?, what to buy them.?
or just guess.?
here ill guess (useless)
1: the FPR reg is stuck closed, and fuel pressures 2x normal an it floods.
got 50 more...
post a photo of your engine and WIN>
get the first of millions, to do it.
amazing at it seems...
learn that almost all cars have
engine options
and transmissions.
May 05, 2016 | Geo Cars & Trucks
Flood switch activated on dishwasher DW60CSWI
Please clarify the model number. i am assuming you have a standard height single door dishwasher. It is likely the flood switch assembly itself is faulty and giving false results. Check the base of the dishwasher - item 95 in on page 10 in this manual. The microswitch could be faulty or the spring might be stuck.
Jan 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Miele G1182 dishwasher not working
Any water comming in to the dish washer area?? If not check the inlet water valve, they get clogged with sand from the water supply. They can also clog open, in which case the dishwasher will flood the floor with water afer about 3 to 4 imins of use.
Dec 19, 2012 | Miele Dishwashers
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Jul 29, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher: BOSCH SHE43 - pump keeps draining
Your dishwasher is stuck in flood mode. Bosch dishwashers are built with flood switches located in the bottom base pan of the dishwasher. The flood switch is connected to a rod that activates a small interlock switch. When water enters the base pan on a Bosch dishwasher, a Styrofoam puck lifts the rod, activating the flood switch.
When the flood switch is activated, the dishwasher will go into a no-fill, only-drain mode. The drain motor may also run with the door open to the unit. This is definitely a sign there is water in the base pan. This can be caused by the drain being clogged. There are two ways to fix:
1. You can uninstall the dishwasher and tip it forward to about a 45 degree angle to drain the water out of the base pan. (This is probably why Ian Bint's solution fixed the problem.) Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and begin a cycle. If it fills and runs, you are good to go.
2. You can also unplug the unit, then remove the kick panel at the bottom in the front. (It's attached with two screws.) Then get some old washcloths or small towels and reach into the base pan below the dishwasher to soak up the water. The pan is directly behind the plastic base panel rim. Once the pan is empty and dry, your dishwasher will no longer be in "flood mode" and will run properly.
If the base pan keeps refilling with water and the no-fill problem returns, there is definitely another issue, such as a clogged drain. At this point, you need to decide whether to invest in an expert evaluation by a certified Bosch repairman and make the necessary repairs, or buy a new dishwasher.
Jun 28, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
I have a fisher paykel soft touch dishwasher about 10 years old. The F1 message came on and we have taken out the inside filters and cleaned enitirely., Was working fine until it came on by itself during...
The flood sensor is located below the bottom drawer. If you take the bottom drawer out and there is water in the pan then the flood switch is probably tripped. Soak up the water with a towel and apply a hair dryer towards the rear left corner of the cabinet. The flood switch is part of the Mains Filter control board and should not be messed with (even with the dishwasher unplugged)... There is an underlying problem that caused the F1 fault and you should have a technician look at it.
Jun 17, 2009 | Fisher and Paykel 24 in. DS603H I Built-In...
Favorit 43070 vi leak
I assume that this leak is from the flat tank on the side of the machiene. Any water leak to the bottom of the machiene puts the washer in ANTI FLOOD mode with the pump out motor activated. You can remove the flat tank by disconnecting the hoses to it and pulling it upwards. If you find a small leak just run it over with a hot soldering iron to melt closed the small leak. Also note that this tank has a small outlet pipe that deliberatly discharges water to the anti flood device (polystireen float / micro switch at the base of washer) in case of a fault (blocked pipe / leak etc).
Jun 07, 2009 | AEG 23 in. Favorit 44070Vi Built-in...
Kenmore Elite - Flooded bottom
this is a necht dishwasher under one year old the problem is as follows. machine switche on make the normal noises to start with after about two minutes it beeps for about twenty seconds machine then stops. The water does not seem to be coming into the machine but a small amount of water does come in at the botom of the machine ie. where the waste is. Please can you help.
Thanks
Nov 19, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Oct 23, 2007 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
43 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
