Question about GE Refrigerators
Model gts18ibmbrcc Freezer cold refrig is lukewarm Freezer back wall had frost water dripping into frig then drips stopped.
dididsaythat
  • 291 Answers
SOURCE: frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Posted on Aug 28, 2007
freetek
  • 5568 Answers
SOURCE: freezer cold refrigerator not cold
It almost sounds as if your fridge is stuck in a defrost cycle.
The timer for this is often located behind the grill at the bottom and sometimes is constructed with a visible shaft that you can mark to see if it is running at all. Some units are constructed so that the defrost heater and compressor can't be on together, others are made so thoughtful. If you don't see a shaft, you might try an old mechanic's trick of using a screwdriver with the tip pressed against the timer housing and the handle pressed firmly behind your ear for bone conduction. If you hear anything like motor noise during the time the compressor is not on, then the timer is probably OK. If you hear nothing, then it might have failed.
Posted on Oct 20, 2008
SOURCE: Side by side refrig./freezer does not cold.
Are the heat exchange coils behind or under the refrigerator clean?
Are the fans running smoothly? Check for bent blades and bend them back if necessary.
Is the evaporating pan under the refrigerator dry.? Then the drain of the defroster may be blocked. Unblock with a steam generator or a long plastic tube.
Posted on Mar 16, 2009
SOURCE: ice buildup in the freezer. dripping from above refrigerator area
I have had water/ice down the back of a Gladiator as well. I just emptied it, disassembled the back wall of the upper portion of the unit. Just a few screws, and one has to disconnect a wire harness, and then after removing styrofoam and yet another panel, I was able to locate the drain hole. It was frozen solid. As I have hot water in the garage, I sprayed some in the drain hole area and then in the lower portion to get rid of some of the ice. After alternating several times (and removing the lower panel on the back of the unit), I was able to see a free flow of hot water from the drain tube at the lower back of the fridge. I have towel dried everything and have a fan on it now so that it is very dry before starting back up. I am guessing that the drain tube starts to freeze in the winter months (I am in Wisconsin), and then just has no way to thaw as it is sandwiched in the back wall of the unit. This winter I may try some extra insulation. Good Luck!
Posted on Jul 21, 2009
kel1guy2002
  • 3740 Answers
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
Posted on Mar 27, 2010
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Unit ED5DHEXWQ bought 2 weeks ago Drip pan over flows- water not evaporating quickly. Company tech say I need to modify my frig by placing a heater. 2 The refrig side is not gettinG COLD ENOUGH - MY MILK...
The tech is full of beans. The heat from a normally charged refrigerator is more than enough to evaporate water in drip pan.
The indication of improper charge is that obvious. Fridge warm freezer ok would be a coil blocked with ice, however drip pan overflowing is a charge problem, Ask for a field supervisor.
Dec 24, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Water is slowly dripping from the top of Frig.
The water is coming from the defrost cycle in the top of unit . It drains down at the back of the light cover into a tube at the back. Get a phillips screwdriver and take it down to be sure tube is inserted properly. Get model number and go to.appliancepartspros.com to get a diagram.
May 24, 2010 | Frigidaire FRT18B4A Top Freezer...
My maytag refrig. is 3 years old. model #747908 HS520AS. freezer on bottom-refrig on top. the refrig part is not staying cold. have cleaned under frig and vaccumed back and underneath and it still is not...
All the cooling coils for this model are in the freezer section. There is a fan down there behind the back wall on the top. This fan directs air up to the fresh food section.
Check the temperature of the freezer you can do this by inspecting the ice cream, if the ice cream is soft you are above 5 degrees F. If you have a good cold freezer then the problem is with air flow, the evaporator fan that I spoke of could be bad).
If your freezer temperature is not as cold as it should be you may have a defrost problem, look for any signs of frost build up on the back wall of the freezer section, if you see frost you will most likely need to put in a new control.
If the freezer temperature is warmer than normal and you do not have frost you may have a sealed system leak, this will require a technician for sure.
Apr 18, 2010 | Maytag Refrigerators
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Model Number TBXW25FP Refrigerator has large volume 1/2 water accumlating inside on the bottom under the Veg and Fruit Trays, unable to locate any source. Need to sponge out every two days. What are...
your freezer drain is plugged and water is dripping into frig you need to get fixed and soon or it will freeze air openings to your frig and stop cooling
Aug 21, 2009 | Refrigerators
Refrigerator not cool
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Aug 19, 2008 | KitchenAid Refrigerators
Freezer works but frig is not cooling
Aug 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
