Question about Garden
Husqvarna 50 Chainsaw - chain wont engage with throttle
It's like the clutch isn't engaging when with throttle. The clutch looks like it is still ok. How can I test to see if it's engaging and if the clutch is engaging but I still don't have a turning chain what other issue might I have? Chain was working fine and then over about 10 minutes became less and less tension until once I try to engage the chain into wood the chain would stop though I had throttle.
  • 1 more comment
  • Anonymous Mar 16, 2014
    chainsaw troubleshootingProduct: Electramac 335. 953900309 - 1650W - 14"/35cm. I recently had an issue with the unit. The chain was turning but when you put pressure to cut the wood, the chain stopped turning with the motor still running as if the clutch was in neutral. Now the chain does not turn when the unit is on and the motor is working.
    Product: Electramac 335.953900309 - 1650W - 14"/35cm.I recently had an issue with the unit. The chain was turning but when you put pressure
  • Anonymous Mar 31, 2014
    What is the problem?
  • 16 Answers
If you lost tension on chain and now it wont turn you might want to check sprocket
Posted on Nov 11, 2008
The tines on a honda f220 always spin and don't change speed when clutch is engaged but speed up when throttle is increased. Adjusted cable with no luck.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
Sep 24, 2012 | Honda 25cc 4-cycle Mini Tiller
Is not working electric clutch for cth 1736 husqv. ride on repairable ?
Unplug clutch wiring from clutch and apply 12v directly to two small terminals in plug, polarity doesnt matter. This will test clutch. The clutch is not repairable.
Jan 31, 2012 | Husqvarna Garden
2000 Buick LeSabre a/c clutch will not engage. Fuse is good, can't tell if micro relay is ok or not, no power at compressor clutch plug when a/c is turned on. Are there other switches (full throttle...
There is a low refridgerant pressure switch, and a high refridgerant pressure switch. Either can cut the power to the clutch. You will have to check the pressure in the system to know for sure.
The electrical part in the clutch could be bad. You could run jumper wires to the clutch connector to see if it will engage. If not, its the clutch. If it does engage, then more than likely your just low on refridgerant, and possibly have a tiny leak.
Aug 29, 2011 | Buick LeSabre Cars & Trucks
Ac clutch not engaging. R134a pressure ok and fuses check out okay
How did you check the pressure if the compressor isn't kicking on ? there is a reason I am asking.
Apr 26, 2011 | Dodge Durango Cars & Trucks
T Maxx 3.3 full throttle issues.
Sounds like either the slipper clutch is too loose or the clutch shoes are not engaging the clutch bell.
Jun 16, 2010 | Traxxas T Maxx 3.3 Monster Truck
Honda V1100 Jumps out of gear on full throttle acceleration
More likely it is a slightly bent shift fork not fully engaging into second. The clutch and bearings are not suspect. Remove your foot from the shift lever then go full throttle in 2nd. Those new riding boots may be doing the magic unconsciously. Adjust the shift lever height if that is the problem.
Apr 30, 2009 | 1994 Honda VT 1100 C Shadow
Starter spins freely, will not engage
there is a coil that pushes starter out to engage it to flywheel and a motor part that turns it. check to se if the coil part is good or hooked up.
Apr 22, 2009 | 2000 Yamaha WR 400 F
Garden Logo
584 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
