Panasonic TX-42PT10 42" TV
Problem for Panasonic TX-42PT10 42" TV
Please Help - Set "Dead" Euro 7 vp chassis
By tweakz on Oct 14, 2006
Television died the other day most unexpected, Symptoms:
1. On switching on there was a high pitched squealling with a flickering screen then auto switch off after 10-20 sec.s standby light flashed three times.
2. On switching on now there is a clicking noise which lasts for 10 sec.s then shut down.
no squealling noise or start up.
looked at main fuse - ok
looked at "P" board -seemed ok
looked at "A" board- solder on R9611 thru R9615 seemed a bit rough but checked out with meter,
Would really appreciate some direction on next course of action, Can you help
regards jon
Same Problem
May 15, 2008
-   please someone can give me the schematics for this tv or service manual. my tv 3 blink red light and off. i see pcb and see a S4 Pin in a transformer that dont have too much solder i think is a problem or just a fix made by panasonic. ths-   mikaspt
May 13, 2008
-   some problem here. disconnect 1 week connect to 220v and voila it works.
this is not the first time before happen turn off from ac wait 1 or 2 days and voila work for mouths. dont know what is the problem but maybe its a lamp/tube problem.-   Guest
Best Solution
posted on Oct 16, 2006
Helpful)
Coil
Rank: Wiz
Rating: 81%, 300 votes
This sounds like a line timebase failure. The line timebase works at about 15 thousand cycles per second (15KHz) which may be audible to some people due to the iron-ferrite materials used (magnetostrictive).
The line output transformer is highly stressed and also has the rectifier diodes in the outside if the windings. It is all very well insulated to guard against moisture and dust but if it breaks down due to the high voltages (25Kv) the arc produced makes this squealing noise, and of course it burns out, and breaks down. This may not blow the fuse if there is not a short circuit. So get an engineer if you are not sure about changing the line output transformer.
Was this helpful?
Yes
No
Popular Solutions for Panasonic TX-42PT10 42" TV
Questions and Unsolved Problems for Panasonic TX-42PT10 42" TV
Do you recommend Panasonic TX-42PT10 42" TV?
Answer
Answer
i have a panasonic TX 28PS1 than wont fire up there is power as the sandby light is on? is there any... (More)
Answer
when I hit the power button I hear a chirping sound and a little red light blinks 3 times in the... (More)
Answer
tv gone into standbye mode
Answer
My 27'' RCA flat screen TV has good picture and sound. It turns itself off and back on sporatically... (More)
Answer
red outline and shadows on screen
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
