Question about Acer Aspire L100 PC Desktop
L100 heat problem
You posted that you have a solution to the Heat problem on L100... mine keeps overheating... could you send me the solution... higginh@yahoo.com.... thanks...
We purchased 10 of these for our dealers since most of them have space constrains. I found that I had to reapply the thermal compound on just about all of them, since they all had a problem of spinning up the fan and then shutting down.
What you do is get some MX-2 Thermal Compound
--> Open the case with the one screw on the back
--> Once open, undo the 4 screws that hold down the heatsink - the copper looking thing - the fans stay in the case. The screws will NOT COME OUT. Just leave them attached to the heatsink.
--> Take some cleaning alcohol and put some on some cloth. Then use the cloth to wipe the old thermal compound (grey goop) off the CPU and the Heatsink.
--> Apply a couple "drops" of the MX-2 on the CPU and use a credit card to spread is it over the CPU. NOT TOO THICK. In fact, I found a complete coverage, while trying to get it as thin as possible seems to get the best cooling effect.
--> Re-apply the heatsink by screwing in the screws one by one, switching to the next screw which is diagonal to the previous one. This way even pressure is applied to the headsink.
--> Close the case and refit the case screw.
All of our computers have worked great after that fix. Hope it works for you.
Posted on Dec 04, 2008
Why won't my excavator stop overheating?
Search Results
    Solving Hydraulic System Overheating Problems
    www.machinerylubrication.com/Read/680/hydraulic-overheating
    Overheating ranks No. 2 in the list of most common problems with hydraulic equipment. Unlike leaks, which rank No. 1, the causes of overheating and its ...
    Cat 320 overheating - Heavy Equipment Forums
    www.heavyequipmentforums.com/showthread.php?2828...overheating
    Mar 28, 2007 - 15 posts - ‎10 authors Anyone here have a problem with a Cat 320 overheating? ... that many heatingproblems in excavators are caused by hydraulic problems. 5T Excavator KX161-3 overheating
    Apr 22, 2013
    john deere 270D excavator over heat
    Aug 1, 2011
    cat 305CR overheating issue
    Jul 23, 2011
    cat 312 overheating
    Jul 31, 2008
    More results from www.heavyequipmentforums.com
Oct 14, 2015 | Cars & Trucks
2001 Saturn l200 overheating ? Changed temp sensor, radiator, waterpump thermostat and it stills overheat. No heat in side. Could thermostat still sticking even if it's new
OK sounds like head gasket or vapor lock hope its vapor lock need to bleed off all air in system turn on heat while radiator cap is off feel top hose make sure both hoses are warm with everything changed is fans even coming on an if not turn on ac an see if fans come on or not
Feb 06, 2015 | Depo Auto Parts Saturn L100 L200 LW200...
My 2003 dodge durango keeps overheating , i just had new radiator put in and it started overheating again but now it is overheating with a very loud screeching noise like a belt sound what could be ca
as for noise will have to inspect under hood,could be fan or belt or pulley ,water pump .these are some things it could...My suggestion for overheating is replace thermostat. If your car has electric cooling fan then it may not be working..turn defrost on and if fan kicks on then fan motor is good..Now this does not mean that fan is working properly because fan is controlled by heat sensor switch that kicks fan on when motor reaches heat range......Things i would have checked....hope this information helps and good luck and Please rate my post...
Aug 17, 2012 | 2003 Dodge Durango
Keep heat up mother bord delay opening program
Good day. In response to your problem i suggest for you to get a better heat sink. There is a big possibility that its the heat sink or the fan in your computer is not doing your job. You can also try to clean the motherboard from dust by using a vacuum. Make sure that the room is not too hot for your computer or near any device that emits heat. Hope this info help you a bit. Have a great day.
May 22, 2011 | Acer Aspire L100 PC Desktop
How do you cure 2 red ring lights on xbox?
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
This is the overheating issue.
Feb 13, 2010 | Microsoft Xbox 360 Console
What is Heatsink Pamris UMA Forcecon?
Yes that was the same thing. seems like they keep replacing your heat sink, you might have cpu overheating problems. try to get a laptop cooler. that should keep the temp. down
Oct 20, 2009 | HP HEAT SINK
Like many others, I have an overheating problem especially with games. I am looking for a repair manual in order to clean and check the heat sink. The Acer website only posts Owners Manual. Any idea where...
it sounds like an overheating issue. download everest home edition andhave a look at the temperatures of the graphics card. the 7000 isntreally a gaming card, but it should'nt overheat without overclocking...
Sep 14, 2009 | Acer Aspire 7520-5185 Laptop
Acer l100 will not boot up
To all of those out there with an Acer Aspire L100 SFF that has decided it will no longer boot -
Symptoms: fans spin up, DVD spins up, possibly HD spinning up - no power, HD or network lights on front panel.
Previous Fixes: Changing out 3 capacitors on the mainboard, re-seating memory and processor.
I tried all three of the fixes above and still no joy. I discovered to my surprise that this PC, due to it's heat "issues", had developed a malfunction similar to the XBOX 360 and Ibook G3...it's video chip had developed some connection issues with the mainboard. Due to the heat, the BGA solder connections under the chip has either flexed and become disconnected or corroded with the same result;
Try this: Remove the DVD/HD "sled" - Using 3 fingers, put pressure (not enough to break the mainboard, but a fair amount) on the heatsink for the video chipset. While doing this, press the power button. If it powers up, this is your problem. You might have to try a couple of times with varying amounts of pressure on the heatsink.
Tools: Needle nose pliers,philips screwdriver, small flat blade screwdriver, new heatsink compound (I suggest AS5), a heat gun
The fix: Firstly, the mainboard must be removed from the case, and the heatsink removed from the video chipset. To remove the push-pins, use a pair of needlenose pliers from the back of the mainboard to squeeze the expanders to release the pins. If yours is like mine, after removing the heatsink, you will find that the thermal compound has hardened and is no longer effective...have some AS5 handy. Second, place the mainboard on a flat work surface. Make sure memory, cables and mini-pci wireless card have been removed. Starting about 4 inches above the video chip, put your heat gun on low setting and ove a period of about a minute, move slowly down until you are about an inch above the video chip (this is to heat it slowly and not cause damage) hold there for 30 seconds - you should notice the solder on all the connections around the chip change sheen from dull to shiny - over about 30 seconds to a minute, slowly lift the heat gun away - letting the heat dissipate slowly. Turn the heat gun off and let the board cool for 10-15 minutes. Third, put a thin layer of AS5 on the video chip core and reapply the heatsink, being careful not to chip the core. then proceed to reassemble the machine.
I did this repair myself 2 days ago...still working great!
Jan 22, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire L100 heat problem
go into the BIOS and disable the smart fan. The next boot will allow the fan to run at full speed, approx 7200rpm instead of 2800 rpm and the machine will not overheat. However, its will sound like an aircraft on takeoff!
Oct 20, 2008 | Acer Aspire L100 PC Desktop
ACER L100 OVERHEAT
Are you comfortable with a little case mod. Just did this myself & solved overheating issue. If interested let me know & I will provide step by step instructions.
Aug 16, 2008 | Acer Aspire L100 PC Desktop
Acer Aspire L100 PC Desktop Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
