Question about Electrolux ICON Designer E30SO75ESS Oven
How can I clean the multiple glass layers of the oven doors?
Dripping, streaking, greasy glass sections on door front are so dirty looking. Can the door and the glass panels be taken apart, cleaned, and put back together correctly? If so, HOW?
  • shafferconst Nov 11, 2008
    I have the same problem, any answers
  • Anonymous Nov 11, 2008
    took smeg oven door apart to clean it, it has 3 panels of glass and i can't remember how to put it back together??
aborcass
  • 2651 Answers
SOURCE: How do I clean the inside of the door window of my self-cleaning oven?
umm. there will always be some assemblence of grease on the door glass, if its on the inner most panel and you can scrub it off, then i would reccomned using a razor blade lying flat to scrape it off, however if it has developed within the panel(s) of glass then the only remedy is to dissassmeble the door and glean them that way.. there was some conflict as to the age of your machine in your description, you say "3-hour cycle for the first use late last spring, if I remember correctly--whatever the directions said to do for the first time, a 4-hour cycle after Thanksgiving last fall and a 3-hour cycle for the second cleaning a couple of days ago since it wasn't very dirty"" so i cant be a mont old??? reason i say is that is the unit you purchased probably come with a pretty kickin warr and the manufacture will want ot make good on your issue if you cant resolve it, betterchance though if only 1 month not 11
Posted on Oct 26, 2008
mastatech
  • 478 Answers
SOURCE: Cleaned oven now door will not unlock
Turn off the breaker for a few minites, turn back on,check it. If still locked use a wire hager and flashlight to push the lever of the lock to the open position. You'll need to replace the door locking mechinisum about 30.00.
Posted on Mar 12, 2009
  • 44 Answers
SOURCE: Electrolux EOB944. How do you remove the Glass
Hi
to remove glass panel you need to open door abit on top of door is 2 screws. undo these but hold handle at same time so it doesnt fall . once scrwes are out prise apart a little bit the lift glass then it should be of . hope this helps
regards dan
Posted on Mar 19, 2009
  • 44 Answers
SOURCE: How to clean the inside of the glass door of Electrolux Wall Oven
Hi
open door and along top you will see 2 screws undo but hold door at same time then just lift out and clean.
hope this helps
Posted on Mar 21, 2009
Maytag317
  • 1136 Answers
SOURCE: how do I remove the oven door to fix the inner
Hi, The picture I looked up is very poor but, I believe you will need to open the door all the way. Look at the hinge and see if there is a small hole that you can insert a small nail into so that the door will not close all the way. Once you get this done, try closing the door and lift up at the same time. This should release the hinge inside the wall and allow it to pull off. Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 15, 2009
How can i clean the glass between my oven door,i noticed streaks and it makes the oven look dirty
Whirlpool door are a bit difficult to remove from the stove. the owners manual may tell you what you need to do to remove it. Once you have it off then the door can be taken apart by removing tye screws that hold it together. This should be done on a flat surface and taking a lot of care. Remember how it comes apart and reverse the procedure when putting it back together. If you break a glass they are expensive to replace if available.
May 30, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
How do you clean the oven door glass inbetween the layers
door needs to be removed and disassembled first. Check My Video
May 18, 2014 | Ovens
We have a Kenmore double oven. Awhile back something spilled as it was being removed from the top oven, and spilled onto the door of the lower oven. Now the glass inside the lower oven door is streaked and...
Please follow the below steps
1)Open the door.
2)Check the hinges and let the door be opened in half way.
3)Use Philips screw head at hinges screws.
4)remove the door and take the inner part alone.
5)Just follow the picture for more help.
Clean it and place it again.
It is very simple you can easily clean it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 07, 2011 | Ovens
THE GLASS ON MY OVEN DOOR IS STREAKED. CLEANER/CONDENSATION HAS GOTTEN UNDERNEATH GLASS. DRIVES ME CRAZY LOOKING STREAKED. ANY SUGGESTIONS? THANKS
usually there is some way to take either the handle off of the door, or take the door apart from the inside and you can seperate the parts of the door and remove the glass and clean it and replace everything back.
Jun 22, 2010 | GE Profile JTP18 Electric Single Oven
How to clean between doors of a wall oven a
2smart4u did not answer the question - how to clean between the glass on the oven door. I too have streaks inside the glass - looks bad - no way to clean it?
Dec 04, 2009 | Ovens
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Dirty streaks between glass front
depends on type of unit,but most separate by opening oven door and removing the screws around the perimeter of the door, be careful reinstalling as to get inner and outer glass re-positioned right along with insulation,this is especially critical because the outer glass can't withstand self-clean temps and will break
Aug 22, 2009 | Ovens
How do I take off the glass on my oven door to clean it?
I have a Kenmore oven and all I had to do was remove the screw at each end of the handle (accessed with the door open) and the very front section just opened up - SIMPLE!! Wiped it down put the screws back in. Did it all by myself - just have your cleaning cloth in reach before you start. Can't believe I looked at those drips for years and it was that simple!!!
Mar 21, 2009 | Maytag CWE4800A Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Electrolux ICON  Designer E30SO75ESS Oven Logo
70 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
