Question about Sony VAIO V505BXP Notebook
Have a broken lcd for a dell inspirion 1500 help!!!!!!
I have a Dell Inspirion 15" LCD that is broken. Completely shattered the body still turns on but no images can be seen. Is it fixable?
  • sillyvg Nov 06, 2008
    thanks for the info hopefully its not too expensive.
    Scholar:
  • 102 Answers
Is your laptop under warranty/extended warranty for accidental damage? If it is inquire from Dell about the procedure to send it to them and getting it fixed click here to get the contact info. If its not under warranty you can inquire Dell for your area dealer/repair shop to get the LCD replaced.
You can also get an estimate for replacing the LCD screen from your local area repair shop to have an idea. In most cases I have seen the technical job performed by the manufacturer is far more superior (Please do not take me wrong, its my experience).
Sorry could not be of much help then to guide you to a right path.
Hope that helped!
Posted on Nov 06, 2008
Caps lock key wont turn off by pressing caps lock light dell inspirion 15
Do caps turn on/off and only the light stays on? Have you tried using the onscreen keyboard to turn it off, assuming it never turns caps off?
Jun 30, 2014 | Dell Inspiron Computers & Internet
My LCD HGTV flatscreen was bumped up against something when moved, now has shatter like image on screen, glass itself not broken...can it be repaired?
No, the display panel which is very fragile is now damaged and the part will cost more that the set did or a new one will cost to replace this one.
Aug 30, 2012 | LG Televison & Video
My Dell E151FP LCD monitor keeps randomly flashing OSD menu, help
The cable might be pinched or bad.Have you tried the monitor on another PC?
Good luck
Oct 17, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Dell Inspirion Laptop Screen Randomly Flickers, Then Blacks Out
If this laptop is only a few monthe old, then it should be still under warranty. I suggest you return it to the supplier for repair or replacement under warranty. If you try to repair it, most likely you wil void your warranty.
If you don't have this choice then read the following info.
You most likely have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 06, 2009 | Dell Inspiron 1100 Notebook
HELP!!!! - Vizio GV47LF LCD HDTV HELP!!! - HOW TO FIX?
When you turn it in, do you get an image? And if it is the LCD screen ( not the front protected glass) then yeah you might as well junk the TV. The cost for a replacement LCD screen exceed the cost of the unit. Sorry about the bad news, just being honest. Turn the television, if the LCD is cracked, then you will see it right away when the television is turned on.
Nov 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
Dell Inspirion 5160 USB/charging problem
well, then, lend me your ears, eh?
sounds like you're right on the front door of a possible motherboard major headache, with charging and usb ports unhappy.
this still under warranty? Check here to make sure
Mar 04, 2008 | Dell Inspiron 5160 Notebook
LCD PROBLEM
if you can get hold of a second Dell Lappy (same model) which is broken (not broken screen) you can swap the broken screen for the good one. It means opening the laptop, but due to the smashed screen the warranty is invalid anyway. There is usually 1 or 2 cables coming from the screen 1 for signal and 1 for power. you can explore the broken lappy to see how the screen connects,
Oct 08, 2007 | Dell Latitude C640 Notebook
Sony VAIO V505BXP Notebook Logo
100 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
