Question about Dometic Rooftop RV Air Conditioner
DUO DERM AIR CONDITIONER
IF THE COMPRESSOR IS FROZEN UP WHAT DO YOU DO, HOW DO YOU FIX IT OR DON'T YOU?
    Genius:
  • 1,605 Answers
When the cmpressor freeze up. unless you have some machenic know how, it is pretty much useless to anyone. even you can rebuild it. the cost for the parts is more than a new one.
Posted on Nov 06, 2008
Frozen compressor
A frozen compressor can be caused by several things. One cause could be partial loss of refrigerant or being over charged by someone adding to the factory charge. Another cause for a frozen compressor might be poor heat transfer in the evaporator, which is where the cool air comes from. This is usually systematic of a dirty evaporator or poor air flow coming from the fan. Another cause for a frozen compressor is the system not turning off when it should. This problem is usually a result of a bad thermostat or the thermostat not turning off soon enough.
JohnL
Apr 19, 2016 | Dometic Rooftop RV Air Conditioner
Why is my Dometic Brisk Air air conditioner not working?
Sounds like the compressor is seized up and the smell is from the clutch slipping when it tries to engage. If that is the case, you need a new compressor at a minimum.
Aug 04, 2014 | Dometic 457915 Duo Therm Brisk Air...
Duo therm fan or compressor do not run
check circuit breaker or bad relay module.
Aug 28, 2012 | Dometic Rooftop RV Air Conditioner
Unit has worked fine for a month. Today it makes a 'getting juice' noise for around 3 sec and then turns off without running obviously. The fan is not frozen-spins easily. The thermostat, a...
The compressor is trying to start and cannot... change the capacitor and if that don't work then the compressor is bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 25, 2011 | Heating & Cooling
I have an RV with a duo therm rooftop air conditioner... when i turn the air on.. the compressor will run for a few minutes.. it blows cold air and then the compressor shuts down. Low freon??
Quite possibly low on refrigerant. Sounds like a pressure switch is shutting the comp. down after it pumps down for a few minutes. Someone will have to check the refrigerant with guages if you don't have any of your own. There should be ports to connect a set of guages near the compressor under the cover.
Apr 13, 2011 | Dometic Rooftop RV Air Conditioner
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
DUO DERM ROOF TOP AIR
yes , this can happen if it sets to long , thats why even cars pumps are engaged when even the heat is turned on , to keep the compressor from siezing up
Nov 06, 2008 | Dometic Rooftop RV Air Conditioner
This is a duo derm roof top air conditioner, possible compressor freezing up
If the compressor is not even trying to start you have an electrical problem in the circuit for the compressor. The thermostat could be open and not supplying power to the compressor or the thermal overload device could be open.
Dometic Rooftop RV Air Conditioner Logo
89 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
