Question about Panasonic DMR-E50 DVD Recorder
No read on some disks and not on others
I've been recording (for example) Dancing with the Stars for 3 weeks now. When I try to record the next show I now get a no read. If I put in a new DVD it works fine. The problem usually comes after I recorded a few shows already. I had this problem with many DVD-R disks that I've recorded in the past with multiple shows, that now say no read. I would like to know if there is any way to get the recorder to read the disk so I can at least finalize the disk and recover the shows that were recorded.
Thanks for any help or comments you can provide.
Sincerely, Roger
  • techguru2 Nov 06, 2008
    I will try to clean the lens as you suggested and see what happens. If this doesn't help what is the next thing I can do?
    Guru:
  • 558 Answers
You need to clean the Lens of your Recorder. Open it with the required tool and go for it.
Otherwise call a repair personnel.
Posted on Nov 06, 2008
  • Puneet Jain
    Puneet Jain Nov 06, 2008
    Also check out if you are using some poor quality of CD/DVDs use a good quality one. And go for try again. Otherwise follow the Solution 1 given by me.
    Thanks for using FixYa, Please rate the solution.
    Have a Nice Day!
    Scott
  • Puneet Jain
    I am sure it will fix the issue, otherwise the worst can be with your Recorder is worn out lens & Head of the reader.
    So replacing lens and Head of the reader will definetly do the trick.
    Thanks again!
My Sony RDR-GX300 DVD Recorder is suddenly only recording the 1st 15 seconds from the DVR. The entire show is on the DVR. I have tried discs that I've used before successfully & new DVD's.
1) pass the Disk cleaner buy to some radio schack, and test it
2) test the cable in another device, and determine if faulty or not.
3) if not clean the terminal from DVD VS TV with c.cleaner
4) otherwise the Syscom inside and another associates circuit is faulty such like record ampl.
go to the repair shop for fix it.
God bless you
Oct 01, 2012 | Sony RDR-GX300 DVD Recorder
Disc inserted but NO DISK message appears
Try other discs to see if its still working properly...most likely the recording on the disc is not burnt properly or there's something wrong with the disc, (ie, scratched or surface dirt etc) or the DVD player just can't read the disc...for example can it read the type of disc(does it read dvd+r or dvd-r, or both?--- if i remember rightly)..... I've had discs that have had bad recordings but can still be read if placed into tray a particular way around... randomly try different positions, also cleaning disc as you go...depending on how desperately you want it to read the disc...could also be bad disc batch... there could be many reasons...
Sep 22, 2012 | Televison & Video
My Panasonic E55 is having problems reading disks after I try to erase something on them. I erase without success and then it tells me the disk is unformatted. Also will not format disk after that. I...
Sorry this isn't a solution, but I just want to commiserate with you. I am having the same problem. I guess the problem started about three weeks ago. The recorder will not recognize any blank DVD-R discs and it only recognized 1 out of 4 new DVD-RAM discs. It would read most of my older DVD-RAM discs but would refuse to erase some of the old recorded programming. It also refused to recognize some of the older DVD-RAM discs, so in frustration I reformatted one. I was able to record and watch a couple of shows, but now it is saying "Unformat" for that disc.
About a year ago, the DVR gave ma some trouble and I was able to fix it myself. (I think it suddenly wouldn't power on, but I don't really remember if it was that or if it was a "SELFCHECK" error.) I had to open up the case and replace two capacitors. I bought the replacements at Radio Shack and my son helped me solder them on. My next step with this DVR will be to open up the case and look for any obvious problems. The worn-out capacitors looked oily and damaged, as I recall.
Sep 16, 2010 | Panasonic DMR-E55 DVD Recorder
Dvd player wont play
Make sure that the DVD Disc is of the format that your DVD recorder can read. For example, if your recorder specifically requires a DVD -R type disk, it will puke on a DVD +R disk.
Apr 12, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Unable to record,cannot read disk,is message on screen,
May be dust/dirt on the lens, so try blowing gently or using a DVD cleaner disk.
Oct 07, 2008 | Panasonic DMR-ES10 DVD Recorder
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Can't Finalize Disk after recording
Your problem may be media related.This firmware upgrade has
helped me and others with similiar issues.
http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-DVD+Recorders#
Be sure to read the instructions.If you don't know understand the
instructions,don't try it.You may make your recorder unusable.
http://www2.panasonic.com/static/Content/productsupport/dvd_firmware_instructions.pdf
Apr 03, 2008 | Panasonic DMR-E55 DVD Recorder
8mm dvd
Have you finalized the disk? I would suggest that you put it back in the camera and finalize.
Dec 27, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
" unknown disc, check disc" message
3 out of 10 will record 30-40 min and say DISK FULL..
2+ out of 10 I'll record 2- 1 hour shows then I'll
get a " disc unknown " error...
www.govideo.com site NOR customerservice@govideio.com works..
did they go out of business ?
who bought them ? where's the support ?
joe_wht@msn.com
Dec 14, 2006 | GoVideo VR3840 DVD Recorder/VCR
Panasonic DMR-E50 DVD Recorder Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
