E5 HDMI 1080i box remains on screen - JVC LT-40DS7BJ
A grey box with the above message remains on the screen at all times. I cannot find anything in the instruction manual on how to get rid if it. It is at the top right of the screen.
  • Anonymous Nov 17, 2008
  • 306 Answers
SOURCE: HDMI to DVI gives pink screen
Make sure the Geforce outputs in DVI-digital
then  Boot the PC while the TV is on and connected. This allows the card to read the EDID from the TV and provide the best resolution...
Most displays work best at their native resolution, which is either 1920 x 1080, 1280 x 720, or 1024 x 768 for most HD TVs. It sounds like your video card has difficulty handling resolutions that high and that may be your problem.
One has to remember that DVI/HDMI is capable of carrying two types of Colourspaces: RGB and YPrPb. Unless modified, the PC will always output RGB.
Do you any other components that use HDMI that you can test, or another HDMI port on your TV that you can use? If not, then the best you can do is swap the cable and contact your provider about the problem,  Make sure the Geforce outputs in DVI-digital
Do you any other components that use HDMI that you can test, or another HDMI port on your TV that you can use? If not, then the best you can do is swap the cable and contact your provider about the problem, as well as contact toshiba if swapping the cable and box doesn't resolve the color problem.
Posted on Oct 17, 2008
SOURCE: cannon MP160 printer error message E5 and alarm light remains on
Problem with catrige.Printer not detecting the catrige so clean catrige,and insert.
Posted on Oct 20, 2008
SOURCE: Grey box on screen saying "No Event" - won't go
happend to me, simple. you need to drag the box back onto the widget bar on the home page and it just goes away!!!!
Posted on Apr 18, 2009
bernardlunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
  • 736 Answers
SOURCE: connect the hdmi out put of a bush hd set top box
its telling you that you cant use the format that your source is set up for .. like 1080P wont play on a monitor that wont support that ..also hdmi requires an exchange of information between units before it will allow 1080 resolution (thats to prevent recording of high resolution material) the adapter may block that exchange .. if you set the source to 720 or less resolution then its likely to start working .. problem is .. if you cant see it how do you set it .. if your remote has an obvious button for that then you can just try selecting different modes and wait 10 seconds to see if it works .. if its not obvious then perhaps you can temporarily use svideo or composite in order to set up the source machine ..
Posted on Jan 27, 2010
My Nokia E5 code problem? What code?
Hello. What kind of code are you asking for your Nokia E5? If it is a network unlock code, you can get it from
http://www.prounlocking.com/nokia-e5/rs5wp9/ at affordable cost. good Luck.
.................UNLOCKING INSTRUCTIONS.................
  • 1 - Switch on your Nokia E5 without any sim card.
  • 2 - Don't bother as to what is displayed on your Nokia E5.
  • 3 - Compose #pw+CODE+1#.
  • 4 - The Nokia E5 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E5 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
  • 3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E5
Jan 24, 2015 | Nokia Cell Phones
How to unlock lock from Nokia e5-00
You mean the network lock?If so, I suggest you can approach Theunlockarena.com and specify the country,locked network of Nokia E5-00.based on the availability you can get the unlock code along with free instructions.
Oct 14, 2014 | Cell Phones
JVC LT-32X787 stays on a grey screen wont open any other things not even menu
Is there a master reset?
Look in your user manual, or get in touch with a JVC tech.
Good Luck.
Mar 11, 2014 | JVC LT46FN97 46 in TV
Hdmi ports are not working
That HD mode.That good what else do u want.Unplug,replug the tv an hour later,might get HDMI ports work again.Not,ur Tuner board is dead.
Apr 26, 2010 | JVC LT-42X688 42 in. LCD HDTV
JVC plasma tv LT-40DS7BJ the plasma screen is broken pls where i can find it , I haved call in diferents places and NOT good replay
that tv is not plasma its lcd , and for what it costs to replace an lcd panel , its just as cheap to buy a new tv
Feb 11, 2010 | Televison & Video
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
Cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
Apr 15, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
