BRAKES INOP ON WIZARD RIDING MOWER
I REPLACED THE DRIVEBELT AND NOW BRAKES DO NOT WORK. I TIGHTENED THE BAR FOR THE BRAKES BUT ALL IT DOES IT SLOWS IT DOWN, IT STILL DOES NOT STOP. ANY SUGGESTIONS???
    Problem Solver:
  • 5 Answers
Check the manual and see if you got the belt config if that not right the tention will not be right also make sure you got the right belt, tention is very important in getting it to stop i hope that helps (compaqsiget over and out)
Posted on Jan 06, 2009
How to change drive belt
Tom, see pages 23 and 24 from the link below. I have the same tractor but with the 22hp engine. It is much easier to remove the mower deck to replace the drive belt. Make sure your brake is set as this relieves tension on the drivebelt system. Good luck.
http://www.husqvarna.com/ddoc/HUSO/HUSO2006_USen/HUSO2006_USen_O0602053_.pdf
Aug 16, 2015 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Poulan 42 parking brake slips
look at sears parts online
Mar 31, 2012 | Garden
My brakes arn't working???
Brakes on mowers wear out like brakes on a car. They may be adjustable. Look on the linkage underneath forward of the rear axle and the brake assembly to see if you can tighten them up a little bit. After that, then you have to remove the rear wheel and replace the brake pads.
I hope this is helpful for you.
Aug 24, 2011 | Troy Garden
I removed the chain brake cover and did not release the brake. is there a way to get the cover back on after the fact?
Hi, carefully put the cover in a vice with the vice jaws tightened up where the bar nuts normally go.Then pull the chain brake lever backwards towards where the handle bar would be. It will require a bit of pressure but it should click back. Then refit the cover.Hope this helps, regards Phil.
Jun 01, 2011 | Garden
I lost my manuel and forgot how to tighten the chainsaw is a 14" homelite bandit
There is a bolt rite under the brake bar usually about 1/2" loosen it and turn the little slotted piece left or right leave about 1/4" slop in chain and tighten nut back up. Good Luck...
Mar 23, 2011 | Garden
Craftsman 14 hp 42'' cut mower brake problems
Well the adjustment is in the rear of the tractor above the axle, their should be 1 9/16 clearance when the parking break is depressed, if it's not here than adjust it until it is making sure to tighten down the locknut when completed. Otherwise just replace your pads via craftsman's website. They provide breakdowns for all their units via the model/serial number of your tool.
Apr 21, 2010 | Craftsman Garden
Computers & Internet Logo
198 people viewed this question
David Payne
David Payne
