Question about Acer Aspire 5500 5570-2609 Laptop
Hi i have an acer laptop and some of my keys have numbers in the top right hand corner, when i try and type the numbers appear instead of letters and i cant seem 2 change it
    Scholar:
  • 53 Answers
You need to turn off the num lock feature. do so by pressing and holding down the FN key then pressing the numlk key just once.
to turn it back on just repet the step above.
Posted on Nov 06, 2008
Keyboard typing numbers instead letters
Hi Tiffany,
The Numlock on your laptop is on that is why instead of letters you are getting numbers. In order to get it back to letters please check the key that says Num Lock where the green light is lit up all you have to do is to press it again to disable Num Lock. If in case you can't see it you may want to try pressing Fn + F11 once and check if you are still getting numbers, press Fn + F11 to disable it. Hope it helps.
Apr 25, 2014 | Acer Aspire Computers & Internet
Can't get past lock code
Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
b>
Feb 05, 2013 | IBM ThinkPad Computers & Internet
Some of my letters are not working
If numbers are appearing instead of letters then -
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Sep 03, 2012 | Toshiba Computers & Internet
My acer travelmate 2410 the letters I o p j k l are typing the numbers 1 to 6 Instead
Has anyone spilled any liquid onto the keyboard?
This is a common indicator as to why the keyboard gives wrong character inputs.
If this is the problem, the keyboard will need replacing
If this is not the case try pressing the FN and NUMlock keys together
Jul 25, 2011 | Acer Computers & Internet
I don't have a lap top but a PC and when I type anything it comes up with numbers instead of letters. I don't have a fn key so what do I do?
Hi.
You have your Number Lock on. Look in at the top right of the keyboard for a key which says Num Lock on it and press that key. That will remove the Number Lock and you will be able to type letters as normal.
Regards.
May 02, 2011 | Dell Inspiron E1505 Notebook
Hi, I've got 2 eeepcs, with identical problems,
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Aug 13, 2009 | ASUS Laptop Keyboard for Asus Eee PC
Ibm thinkpad keyboard right side is #'s not letters
You have accidentally turned on the "Num Lock", all you have to do is hit the Num Lock key to return the keyboard to normal, it is located at the top right hand side of the keyboard.
Regards
Jun 19, 2009 | IBM ThinkPad T40 2373 Notebook
Laptop keyboard is keying irratic numbers and letters
Hi there.
Just hit the NumLock key on the top right hand side of the keyboard and it should return to normal.
Good luck and thanks for choosing FixYa!!
May 27, 2009 | Gateway M-6750 Notebook
Cant find the number lock key on my acer 6920 laptop
I think for your laptop the number lock key is a second function... Try holding down the function (Fn) key and pressing the F11 key, hopefully that will turn your number lock on/off.
Nov 23, 2008 | Acer Aspire 5100 Notebook
Keyboard problem's
Yeah lol!!! shot the cat!
press the fn key and there should be a num key at the very top press those!
Dec 02, 2007 | Acer TravelMate 2300 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
