Drip pan is full of smelly beige liquid and is located at the lower back of the refrigerator, how can i remove and clean the drip pan as it appears to be sitting ontop of a mini compressor. rykard
At the back of the food compartment where the water collects ,there is a drainage hole, this is blocked up,poke a long thin piece of wire or similar and poke it down the hole, this should clear the blockage,
If the water does not drain away then you need to go the rear of the frig and clear the rubber or plastic hose that you will see on the top of the motor compressor. this should solve the problem.
Plz rate this solution.
Thanks. and merry xmas.
I can't seem to find the model # of this fridge on GE's website. (hotpoint is AKA GE Appliances)
If you can give us the model # on the inside of the fridge door I can get the
try searching here if you can get the model # I can't get past the first page with RLA30 as the model.
http://www.geappliances.com/service_and_support/
Best Wishes
Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
Can not find my drip pan to empty on a Frigidaire mini fridge
