Question about Canon imageRUNNER C3200 Copier
Canon np6521 copier
This machine was donated to our non-profit org and is failing bit by bit. first the doc feeder jammed, then the trays kept jamming and now it is jamming with feeds from the outside upper tray. Now it is reading E10 and will not clear. I have turned off power and removed the jam. I have checked the 2 bottom trays and opened all the sections (which typically has resolved the problem)
The number of copies on this machine is only 65K although it is old.
Please help.
Frank Dominick
I really hate to tell you this, but your copier main motor is running to slow on multi runs from over heating and is hard to fire when cold . Anyways the motor is going by-by.
Posted on Nov 07, 2008
How to clear the display error on konica minolta c452
Sir there is a lever in the rear of the machine when you lift the document feeder it is not jam or broke, also there is a small magnet and sensor in the front of the Doc feeder right side and the copier it self ensure the document feeder is properly aligned. Does this happen on the document feeder or on the big glass? Also mite want to have a technician run alignment & tray adjustment.
Dec 06, 2014 | Konica Minolta Bizhub C452 Color Copier,...
Canon ImageRunner2230 Copier, I am trying to set it up to connect to a network for printing, I don't have the CD or the manual. The copier was donated to our non-profit organization without them. I ha
Dear Gregg,
What I'm suggest you to do is,you must directly contact CAA to solve your problem.Refer to your problem,there so many things need to do and your machine condition need to check too.
Thanks
Oct 22, 2011 | Canon IMAGERUNNER 2230 Copier
Error Code 540 on Canon ImageRunner 400s - Have non profit agency and this copier was donated to me. I plug it in and keep getting this error code when I attemp to runa copy - any help out there? Didn't...
E540 Cause : The shift tray home position sensor fails. Description : The home position detection signal does not turn on within 5 sec when making a shift tray home position search.
turn the copier off and disconnect the finisher plug and turn back on the code will go away. if you dont need the finisher take it off and use an exit tray.
Mar 22, 2010 | Canon Office Equipment & Supplies
Cannon NP6521, 531e error
check the sorter staple motor sensor or remove the sorter from the machine
Jan 06, 2010 | Canon NP 6050 Copier
Hi, While loading paper I'm getting an alarm saying E2 though papers are present in the paper tray. I 've pulled the clip in the paper feeder to the left, kept the paper i.e. alligned it to the right of...
Does your printer have a paper tray on the bottom as well? If so there's a feed switch that tells your machine to use the tray or the rear feeder. There's also a small printer picture with a light that either is lit for the top or bottom feeder. To be safe, put paper in both trays.
Aug 13, 2009 | Office Equipment & Supplies
After copying when paper come out it stick with the rollers.
Hi ashraf_snake, first could you be more descriptive in the area of the paper jam. Is it your original that is jamming in the doc feeder or were the paper comes out of the machine?
Mar 25, 2009 | Canon NP 6035 Copier
Imagerunner 330S - just received this copier as a donation (we're a small nonprofit). Machine claims there is a paperjam in paper tray and side drawer. Doesn't seem to be paper in either location. Any...
check whether any sensor spring will open under stack bypass area, under toner area or under back panal fixing area or any short piece of paper in way of paper feeder
Feb 09, 2009 | Canon ImageRUNNER 330s Copier
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
Canon imageRUNNER C3200 Copier Logo
114 people viewed this question
old marine
old marine
