Question about Hotpoint Dishwashers
Hotpoint FDW80 dishwasher showinmg an AL10 fault.
  • m1ajt Nov 15, 2008
    fault code a10 showing ... apparantly the fill valve triac is open or short circuit... A triac is as I understand it a solid state swich but where is it??????????
Thank you for your quick reply.
Our solution - Added salt and rinse agent (I think it was probably the salt). All seems OK. No fault warnings showing.
Posted on Nov 07, 2008
Our hotpoint fdw60 won't wash properly if at all water goes in but it does not seem to wash and we get a code of AL10 too
AL10 means open circuit in heating circuit. ie not heating which will also explain poor wash results.
can be a fairly involved job and should be left to someone who knows what they are doing.
on other hand could be as simple as a broken wire inside the door skin, just remove and give all the wires a good tug.
Jul 11, 2011 | Hotpoint Dishwashers
My FDW80 hotpoint dishwasher has stopped releasing the tablet. The door won't pop open. Any ideas???
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Mar 13, 2011 | Hotpoint HDA3520ZBB Dishwasher
Hi I have a Hotpoint fdw80 witch is displaying an error code AL10. Please can you tell me what this means so I can decide a course of action. Many Thank's Amanda
I found these error codes for the hotpoint fdw80
AL01 - Anti flood switch operated
AL02 - Valve or connections
AL03 - Time out - drain
AL04 - Thermistor (module)
AL05 - Circulation pump
AL06 - Time out - fill
AL07 - Not used
AL08 - Time out - heat
AL09 - Software recogntion error
AL10 - Heating circuit
AL99 - Communications error - connectors, cables etc.
H20 - Time out - fill (taps)
Now looking at AL10 error. Most often it is the heater element which is not effective due to scale formation. Make a solution of white vinegar and water (50:50) pour it onto the base of the dishwasher. Leave overnight and run dishwasher as normal. Somehow the vineger has to reach the heating element which is an inline heater. I am assuming normally you would use the hotwater connection from the kitchen tap.
If this does not help - depends how soon into the cycle you get the error you will have to replace the heater. I think it would look like this.
Feb 01, 2011 | Dishwashers
Fault code AL10
I called an engineer after checking with hotpoint what the fault code was. Hotpoint advised that it was either a faulty heating circuit and I had to check the heating connections and timer (impossible unless you call an engineer).
Anyway, the fault turned out to be something to do with a water feed (I can't remember the technical name). There wasn't enough pressure coming through a particular valve as it was stuck in a semi-closed version, consequently the heating element wasn't switching on as it wasn't 'sensing' enough water pressure.
Valve has been fixed, and the dishwasher is now doing OK! For the time beginning at least.......
Jan 14, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Fault Code AL03 in an FDW80 dishwasher
Al03 stands for problems with the drainage either ur pump is blocked or has just stopped working so not enough pressure to drain out water during cycle
Jan 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw80 dishwasher
Faulty heating element. Had the same error and got Hotpoint to replace the element. Error was also confirmed by their engineer.
Apr 13, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint fdw85 dishwasher error code al10
Hi we've got the fdw80 and AL10 is the heating element. Ours goes wrong every couple of months luckyly we've got extended warranty till 2011. They wont replace machine as fixable so they will be coinng out every 2 months for the next 3 years.
Hope this helps
Feb 13, 2008 | Dishwashers
Dishwashers Logo
606 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
