Question about Microwave Ovens
Panosonic nn-t790 microwave
Panasonic microwave panal went dark, like no power, but the outlet has power.
I pulled the top and sides (one piece) of the microwave. Near where the 110 volt line goes into the unit is a standard fuse ( 18 amp). I used an ohmeter on ther fuse and determined that it was not working and replaced it. Problem solved - unless it blows again.
Posted on Nov 07, 2008
Power shuts off completely
Microwave NN-SD697S; Went i push start switch, some time start and some time not, power it fine. thanks for replying
Feb 02, 2013 | Panasonic NN-SD688 Microwave Oven...
Can I replace the lamp in a panosonic microwave oven model NN CT 857
Hi.
The lamp replacement requires complete removal of the oven external casing. The oven must be tested for radiation leakage after the repair. The replacement must be done by a trained technician. Disassembling procedure is illustrated on the service manual available here: Panasonic Service/repair manuals,schematics.
Regards.
Ginko
Dec 15, 2011 | Panasonic Microwave Ovens
MY PANOSONIC INVERTER SHUTS DOWN AFTER 14 SECONDS MODEL # NNCD989S
Check again.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
Order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 29, 2011 | Panasonic NN-H275SF Microwave Oven
NN-T964SF 1250 Watts Microwave Oven: my microwave went dead and wouldn't turn on at all...
Sounds like a blown fuse. Carefully remove the cover, and the fuse in directly behind the power cord on the top. Radioshack sells 15A ceramic replacements.
May 17, 2010 | Panasonic NN-T964SF Microwave Oven
Panasonic nn-s558ba microwave won't power on
Lee,
Have Landlord replace unit after verifying that outlet has power.
In the future, follow manufacturer's cleaning instructions and DO NOT
run microwave without something in it (even a microwave safe cup of water).
Larry Hanson EH&S Specialist
Apr 04, 2009 | Panasonic NN-S558BA/WA Microwave Oven
Stop working
IS IT POWER UP.
please rmoove the cover and check the fuse also.
is it work?????
nuwan
Jan 11, 2009 | Panasonic NN-S540BF Microwave Oven
Have a Panasonic Micro nn-T790 SA, need to replace light???
If you don't see an access panel inside the oven, you must remove the outer cover to find & replace the bulb. Be sure to unplug the oven first!
Many models use halogen lamps. You must not touch the new one with your bare skin as the oils will shorten the bulb life.
If you don't have your owner's manual, you can download it here: http://service.us.panasonic.com/OPERMANPDF/NNT990SA.PDF
We're happy to help and we appreciate your thoughtful rating of our answer.
May 17, 2008 | Panasonic NN-T790SA Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
