I have a Ricoh IS330DC I'm trying to set up with Windows XP Pro SP3. SCSI Card installed OK (Adaptec), but when I try to access the scanner, either through Ricoh's software or Adobe Acrobat Pro 9.0, I get the error: 12320: Cannot find the scanner. Check if the scanner main power is on. Scanner does not show up in device manager.
  • Anonymous Nov 19, 2008
    same
I had the same problem, resolved as follows.
In the scanner panel, you set NETWORK BOOT = NONE
Antonio :)
Posted on May 06, 2009
  • mohammed omar Jun 06, 2011
    please explain more please i want some help
I am running XP Pro SP3 and have installed a SCSI card and software for the scanner. When opening the utility I get error #5 cannot confirm scanner connection. Please confirm scanner's connection and SCSI...
Hello, just check you have a scsi terminator fitted to your scanner as without one you can get all sorts of bus errors. Also, keep the bus length as short as poss.
n.b. some of the later scsi devices are auto-terminating, so check the spec of your devices, and by the way,. don't plug and unplug your scsi bus whilst it is powered up as this can cause the hardware to blow (it's not like a usb plug and play bus)
Hope this helps!
nicam49
Dec 29, 2010 | Konica Minolta Dimage Scan Dual IV Film...
How do i use an epson filmscan 200 with a laptop running windows 7
were you using it under windows xp? if you have 32 bit windows 7 I would try those same drivers. Unfortunately the filmscan 200 came out under windows 95/98 and so Epson never released XP drivers and some people were able to make it work.
I would consider connecting it to an older computer running windows 98 and then transfer the files as you scan them (this would definitely be the least painful)
If you have 64 bit windows 7 I would not even waste the effort, 32 bit is a long shot maybe.
Do you have scsi drivers on the the windows 7? because the filmscan 200 is a scsi 2 device
Good luck
Nov 24, 2010 | Epson FilmScan 200 Film Scanner
Can someone advise if the Epson GT-7000 scanner which I had working in XP can be made to work in Windows 7 or is it time to throw out my faithful machine? Rodney.
I got mine working on Windows 7 (x64) by doing the following:
1. Download the Windows 7 Epson Scan driver for the Perfection 2400 from the epson site 2. Install the drivers 3. In Start Menu->All Programs->Accessories right-click Notepad and select Run as administrator 4. In Notepad File->Open and browse for the es27.inf file located in C:\Program Files (x86)\epson\escndv\es0027 5. On line 51, 54, and 57 replace PID_011B with PID_0101 6. Save the file. 7. Connect and turn on the scanner. 8. In Device Manager (Start Menu, right-click Computer, select Properties, Device Manager) right-click the scanner and select Update Driver Software->Browse my computer for driver software 9. Select the location of the modified INF file (C:\Program Files (x86)\epson\escndv\es0027 Include subfolders checked). 10. Say ok to the window that pops up and it should start installing the drivers.
In Photoshop you should then be able to import using WIA-Epson Perfection 2400 (importing with Epson Perfection 2400 causes Photoshop to freeze)
I hope that works for you :)
Stephen
Sep 28, 2009 | Epson GT 7000 Flatbed Scanner
Install XP on SCSI HDD - Instellistation Z Pro 6223-CTO
Have you tried putting the drivers on a flash drive.
It is a method I have used to get drivers into the windows install.
Try it with the "press F6 to install drivers" during the text setup phase but make sure they are the dos level drivers that you try first !
If that fails then try the windows level drivers
Worked quite well on lots of early SATA stuff so you have nothing to loose.
You might also want to check that the various usb settings in bios are set to legacy etc too.
Aug 20, 2009 | Computers & Internet
How to install Adaptec SCSI driver when installing XP -Z Pro 6223
you have to use sata xp cd to intall that driver no need floppy disk.
Aug 19, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Adaptec AHA-2940 UW PCI SCSI CONTROLLER
If you are using Windows XP, the drivers are embedded. It will automatically recognize the SCSI card. For other OS try http://www.adaptec.com/en-US/support/scsi/2940/AHA-2940UW/ S. Mohan.
Jun 09, 2009 | Canon Office Equipment & Supplies
I need info on the make of scsi card that is bundled with scanner
It may be an old Adaptec SLIM-SCSI series. Very popular on Late 90s
1. Adaptec PCMCIA Fast SCSI Controller ( 1807600 ) - SCSI Controller ...
    "Adaptec Storage SCSI Controller Card, Storage 1807600, Adaptec PCMCIA Fast SCSI Controller."
    www.superwarehouse.com/Adaptec_PCMCIA_Fast_SCSI_Controller/1807600/p/88814
2. Adaptec SlimSCSI 1460 review - IT Reviews
    "Adaptec is the king of SCSI connectivity devices and currently offers two PC Card (PCMCIA) SCSI cards. The 1460 is the jack-of-all-trades model, ..."
    www.itreviews.co.uk/hardware/h82.htm
3. Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0 ...
    "Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0.2183.1 - Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter."
    www.soft32.com/download_171850.html
Jan 18, 2009 | Umax PowerLook 2100XL Flatbed Scanner
IBM Blue Screen
I had the same problem with an Intellistation 6868 for years. It just wouldn't load XP but ran fine on Windows 2000 SP4. I tried 3 different XP Installation CD's with no luck. After several attempts at installing XP I bought a clean XP Upgrade from ebay.
It took me 3 goes to install it but eventually I got it in there. If you can get XP to start on the 6868 press F8 and start it in safe mode first then when it's booted fully, shut it down and and then start it clean again. It worked for me. I've been running it for 5 months now and it's fine.
I couldn't get it to work at all on the 6868's onboard IDE so I installed a PCI Raid Card and it boots fine on that.
System:
IBM 6868 52A M-Pro Intellistation
2 x Intel P3 866 CPU's 256 mb cache
2 GB ECC RD Ram
2 x Seagate 320 GB 8MB Cache HDD on a Sunix ATA133 PCI Raid Card
2 x Seagate 10000 rpm SCSI HDD on Adaptec Raid Card
ATI 9520 AGP 128mb Graphics
Win2000 Professional SP4 - Upgraded to XP Professional Edition SP3
Dual Boots with Xandros Linux Desktop Destop 3.01C
Sep 08, 2008 | IBM IntelliStation M Pro 6868 PC Desktop
Nikon Scan doesn't recognize scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
1,214 people viewed this question
jasbo
jasbo
