Question about GE JVM1640 Microwave Oven
Replace light in JVM1460BA and SPARK!
Patched burned out wire, but relay just clicks when
pushing the "light" button.
  • GE Master
  • 9,098 Answers
My answer assumes the wiring from the controller to the light sockets is all okay now and the sockets are fine.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Posted on Nov 08, 2008
How to fix micowave, Bottom light and fan are on all the time, no response from keys after changing PCB board ?
The door switches are ok you say...this is weird...the light will not turn off..did you take pictures of the old circuit board, and put the wires back on exactly as they came off...I always take pictures as my memory and sight are not what they use to be...let me know further..and if the new board was updated, did it come with instructions on a new wireing setup..some change the way things are wired after a new updated board has be replaced....
May 21, 2014 | Panasonic 1100w over Range Microwave Ovens...
It shows se and will not work
You have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so there is a paint to repair microwaves for this issue or else just dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Dec 01, 2013 | Amana Radarange Microwave Oven
LG. Why are wires attached to KSD1 150/0 (MGT Thermostat) burned?
If the wires were loose and cause them to burn under a load. Loose terminals cause high voltage and burn switches, relays and thermostats. I hope this helps you.
Nov 23, 2013 | Microwave Ovens
I open the door to the refeg and it smells like wires are burning. I unplugged it. The lighting fixture is loose. The plastic around the light is defected.
A loose connecction of the bulb holder can heat up and burn the holder plastic material -- as a faulty connection will spark and heat up. The best option is to remove the holder , rewire and replace the unit.
Jul 02, 2011 | Microwave Ovens
Set time to cook and hit the start button and all that happens is a click like a relay immediately after pressing the start button. Also in the past the fan and turntable would occasionally come on when...
Bad door switch, look at the wires going to the switch and see if any look browned or like they were hot. Make sure each switch clicks when you push the plunger down and release it. I always replace the switch with one that has 1/4 inch terminals as they hold up much better then the ones with the smaller 3/16 terminals. Just beefier and better.
Sep 23, 2017 | Whirlpool MH7135XE Microwave Oven
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Exact same problem - Needlenose slipped and spark in the socket
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You have a short in one of the door safety switches
There function is prevent the oven to work whit the door open
some are normally close and some normally open when one of then don’t work properly causes a short and blow the main fuse check the all and replace the faulty one but be careful and don’t test the microwave
Whit the cover removed.
Note:
if you have a blown fuse buy several emplacement fuses because my take several trays to fix the problem and you will need more than one fuse.
Jun 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Majic Chef cabinet mounted microwave oven model VM11B-8P
On the electronic control board, the circuit trace will open like a fuse if the light bulb power becomes shorted. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for a burned, open circuit trace.
4. Repair circuit trace everything should work again....
Jun 15, 2008 | KitchenAid KCMS145J Microwave Oven
Unit does not turn off
open the control push boton and clean it one of the boton stoct.
Sep 19, 2007 | Panasonic NN-S254WF Microwave Oven
GE JVM1640 Microwave Oven Logo
108 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
