While trying to play a DVD on our JVC TH-A9 home theater system, on inserting a disc it did not start to spin and consequently disc did not read . When the " Now Reading " message ended the display changed to 0:00. Any ideas as to what may be wrong? I tried a CD and it also refused to spin etc. the laser carriage moves and light is showing for laser but thats about all.
If a disc will not spin, A- the laser may not be focusing on the disc, as it must do this before it will spin and read the TOC. ( table of contents) B- you could have a fault in the spindle motor circuit or the motor could be bad. You will need to find an authorized servicer if you do not understand solid state repairs. Good Luck PS please dont forget to rate this.
I Have the JVC THA9 system and need the connector to SP-PWA9. Does anyone know I can get this cord?
Thanks
Lee
Non-playable discs
• DVD-ROM • DVD-RAM • DVD-R • DVD-RW
• CD-R* • CD-ROM • PHOTO CD • CD-RW*
* Audio formatted CD-R and CD-RW can be played.
• Playing back discs list as "Non-playable discs" above may
generate noise and damage speakers.
Our JVC TH-A9 stopped working. It does not spin the dvd discs any longer. It says reading, then nothing happens. I was thinking it might be the motor, but am not sure where to take it to get it repaired.
hi there , I have the JVC THA-9 Home theatre system as well , my kids were playing with the remote and now when i put in a dvd the dvd player does not read the disc and says PAL DISC . Nothing happens at all , I have tried to play around changing the mode to dts ....There is also a display which says LINEAR inear on the screen , pls assist if u can thx , pls mail me your solution on [email protected] , thx so much
same exact problem. I can play another disc in the system, and it works. I can take the DVD that does not run on the JVC, and it will run on any other player. So, it is just this one disc on this system.
i have a jvc th-g40 home system.now.. i put in a new dvd or cd it wont play it... it say no disk. before it use to play... a disk from rebox it will not play but, it will play other such as some disk i may burn.... i figure i would buy a cleaner.. i did. i got a new memorex cd/dvd optidisc cleaner.. it wont plat that... what should i do.. just take it to the shop or what?
No music because it stays in READING
