Question about Brother EM-430 Typewriter
Setting Margins I've lost the instructions for my Brother AX-450 typewriter and can't remember how to set the left and right margins. Can you help?
    Scholar:
  • 183 Answers
Move the carrier to where you want the mar.set then hit the R MAR or L MAR key.
to move the carrier beyond the margins hit the MAR REL key
Posted on Nov 25, 2008
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
I have an SX-4000 Electronic Typewriter and use it from time to time BUT I do not know how to reset the margins....basically expand them beyond the norm. Please help - I did do the ALT and then the 4 or 5...
Try this procedure to set and adjust the margin:---- Use the "Space" and "Backspace" keys to set the margins by positioning the carrier where you want each margin. Press the "Alt" key along with the "L Mar" or "R Mar" key, depending on which margin you are setting, left or right.Press ALT with L Mar key to adjust margin on left side.Press ALT with R Mar key to adjust margin on right side. ----------------- For more help.Click this link below and check page number 11:---- http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF ------------
This should help.Thanks.Helpmech.
Jan 05, 2011 | Brother SX-4000 Typewriter
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
I bought a --brother AX-400 electronic typewriter at yard sale... please help me set left and right margins...
Move the carrier to the desired position for the new left or right margin using "backspace" or "space"
To move beyond the position of a current margin, first position the carrier on the margin and press "alt +m rel"
When the carrier is on the desired position, press "alt + l mar" (if you are setting the left margin), or "alt + r mar" (if you are setting the right margin.)
The minimim distance between the left and right margins is two inches
Jul 18, 2009 | Brother ML-300 Typewriter
Left and right margins of typewriter on Brother ML 500 Memory
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
Mar 19, 2009 | Brother ML-500 Typewriter
How to install min L MAR on the Brother Typewriter AX-450
move the printhead to where you want the L MAR set then hit the L MAR button, if you want to move to the left of where the L MAR is set, go to the L MAR by backspacing or  the return key, hit the MAR REL button and backspace to where you want the mar set and hit L MAR.  the right margin works the same way
Feb 25, 2009 | Brother Office Equipment & Supplies
What keys do I use the change the left and right margins?
You set the margins by putting the printhead where you want the margin set, and holding down the CODE key, push the key under where L MAR or R MAR is printed, (above the top keys on the keyboard) depending on whether you want to set the right or left margin.
If you want to set the left margin to the left of where it's set, hold down the CODE key and push the key under MAR REL. Then using the Backspace (or spacebar, if you backspace too far) position the printhead where you want the mar. set and holding down the CODE key, hit the key under L MAR.
Setting the right margin works the same way.
Oct 27, 2008 | Brother GX-6750 Typewriter
SETTTING MARGINS
Use the margin release or mr key to be able to get past the current margins. Position the carrier to where you want the margin then press left or right margin set. Lawrence
Jul 27, 2008 | Brother SX-4000 Typewriter
Margin Release for Brother GX-6750 Typewriter
Typewriters have alimit to how far to the right or left that you can set margins. Once you use the alt & 6 key to bypass the current margin setting then move to the new setting then hold the alt key and touch the 7 key to keep it in the new position.
Mar 09, 2007 | Brother GX-6750 Typewriter
Brother EM-430 Typewriter Logo
369 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
