Question about Technics Audio Players & Recorders
Slow speed I am having a problem with the variable speed control. I cannot get the speed up to 331/3 rpms when playing an album. Is this something that can be fixed or do I need to purchase a new speed control assembly? Where can I find a control assembly? Thanks for any help you can provide. Kenny
What model do you have?
It could be a few things. It may be as simple as an adjustment to the pitch control (if your table has one), it could be the pitch control itself or something more serious.
Is it Belt-driven or Direct drive?
[J]
Posted on Nov 14, 2008
How do I fix the speed of my Jensen JTA-460 turntable? I've tried numerous records that previously worked perfectly, but now the speed is too slow regardless of what album I try.
Could be the belt for the pulleys is stretched a little, or there is something making it slip, or the potentiometers were set incorrectly from the factory . It is normal to have one for each speed. It is unknown if you can access these from the bottom of the unit. Slippage is less likely to be caused by something oily, since it would alternate the speed faster and slower and yours seems to have worked then reached a constant slower speed. Do your 45's and 78's play ok? (yeah I know, does anyone have a lot of 78's on hand)
Your model does not have an outside pitch control to fine tune the speed faster or slower. Another Jensen model JTA-230 does. Entry level turntables such as yours are not speed accurate reliable. After reading reviews on your turntable, it's possible that the belt is the problem. If the slow speed problem had happened from the start, it would be safe to say that the speed wasn't calibrated correctly and you could have returned it and perhaps had better luck with another one but because it worked fine at the start and then now plays slower, it's either the belt or the potentiometer for the 33rpm speed has somehow changed.
May 23, 2017 | Jensen Audio Players & Recorders
Porter cable scroll saw runs slow
If you bypass the speed control does it run/spin up like before?
Sep 12, 2016 | PorterCable 1.6-Amp Variable Speed Scroll...
How do I fix my generator
the first thing that I can think of is your engine speed is to slow causing the frequency to be below 60 hz. At half the hertz 30hz the tool will run at half the speed and most likely burn out since most tools are not built to run at variable frequencies. A 4 pole generator (the norm) needs to run at 3600 RPMs under load. Unloaded they are set at 3750 RPMs since they'll slow down slightly under load. There are many throttle setups for small engines so I can't give you a step by step on adjusting the throttle arm on your machine without seeing it. Oh, just a thought, does it have auto-idle button. If so turn it off, for some reason it is not sensing the load. If you have a multimeter with frequency on it, you can use it to help set the rpms.
Aug 05, 2016 | Electrical Supplies
My Gemini TT 02 gets stuck at 45 RPM. To get back to 33 you have to turn off and on again. Also the pitch is wildly out by about +7. Is there any way I can repair this?
Your terminology confuses.
Point 1. Why to you say, "Stuck?" Does it not make sense as a possiblity that the designers sought to prevent rotaton speed from being changed mid playback, especially on, say, an LP (long play) album with different side (stereo instead of 45 monaural) grooving. What would be the imperative of changing record speed in that manner...only one record type will play at a time. If changer, only one type record seriies can be played, all at the same speed.
Point 2. ...about "pitch...wildly out by about +7.
First, what are you meaning by pitch and by + (not -) 7. Since there is, to my knowlege, no record spin criterion known as pitch, are you referring to spin speed; hence to playback sound frequency, whether steady state or variable? If there is no user control of platter rotation speed on your unitn there would be little you can do other than to ensure all parts above and below platter are running smoothly with no drag or interference...possibly even lightening the record load on the platter, if a changer; and making sure records are clean to prevent slippage by washing with water or soap and water and air drying--avoid label. If your turntable is optically speed controlled (by timing marks on platter rim) those are typically adjustable to hasten or slow platter speed and therefore playback frequency pitch to your liking. "Wild variation" could reflect mechanical impedance as indicated above. Also check for record warping by trying known true record playback. Finallly, wild variation could be indicator of platter motor end of life cycle. Start pricing a motor if nothing helps.
I still don't follow the significance of the speculative(?) 7. Please explain if possible.
Sep 27, 2014 | Audio Players & Recorders
RPM surges intermittently from 1000 to 2000 at idle or slow speed
ok a couple of things to try one is loosen the throttle cable so it has a little play in it and then you can check for vacume leaks using carb cleaner if rpms change you have a leak
Aug 17, 2009 | 1994 Honda Accord
How can I fix my tape player?
this unit has a variable tape speed adjustment ("pitch control"). Make sure this is set at the middle (neutral) position
Jan 11, 2009 | Tascam CC-222mkIII CD Player / Recorder
While wathing movie by acer 3260 laptop video & audio slow
Hello sanjeev_vada,
This procedure is from the windows media player help file.I hope it's useful:
*To play content at variable speeds*
You can change the speed at which content plays in the Player. For example, you can slow down the playback speed if you are taking notes while watching a training video, or you can speed up the slow sections of a presentation.
•Begin playing a file.
•Click the arrow below the Now Playing tab, point to Enhancements, and then click Play Speed Settings.
•Move the Play Speed slider to the speed at which you want to play the content, or click the Slow, Normal, or Fast link.
•To select speeds between the labeled play speeds, in the Enhancements pane, clear the Snap slider to common speeds check box.
•To hide the settings, click the Close button in the Enhancements pane.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 05, 2009 | Microsoft Windows Media Player
Drill press
Release the belts and check if you can turn the chuck by habd, if the chuck won;t turn, two things could be wrong, 1) the quill bearings are bad or 2) the shaft that runs down thru the quill could ve rusted causing a restriction, if that's the case, WD 40 should loosen it.
Oct 24, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Variable speed Control problem
When you are finishing the surface, it's vital to maintain control. Work too fast or too slow and you risk ruining your hard work with unsightly scratches
Aug 27, 2008 | Vector Vec 260 10 Inch Waxxpro...
226 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
