Question about Bosch Refrigerators
I have a Bosch upright freestanding frost free freezer. Moedl number GSU 3401. It is about ten years old and has functioned perfectly until a few nights ago. The temperature keeps rising which sets off the alarm. It only seems to maintain the correct temperature if the superfreeze is kept on. As soon as we stop the superfreeze the temperature rises and then the alarm goes off again. Any clues?
Sounds like it needs regassing
Posted on Jul 03, 2009
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
Food defrosted in top of upright freezer
Sounds like a defective defrost timer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost thermostat, heaters, or trimmer
Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up
Hope this helpout and Good luck
Jul 28, 2010 | LG LRTP1231W Top Freezer Refrigerator
Taking out trays for cleaning
Usually the holes are deeper than they appear in the side walls. Lift the shelves just a hair and then push them left...the right side should now be outside the hole and able to be moved upward until left side clears.
Reverse this process to reinsert. Good Luck.
Aug 21, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer - top shelf frosted over -- poor cooling through rest of freezer
Hi yadak,
Happy to help.
You may need a new door seal.
But they are not easy to put on properly
and I would not recommend spending a lot of money on a ten year old freezer!
the new ones are much more energy efficient and will save you a lot of money!
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 08, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Not all shelves freezing Alarm on
If this is not a frost free unit. I say replace it. I don't believe in recharging a deep freeze. You can never really trust them again. The food inside is worth more than the freezer. If this is a frost free unit, See if the fan inside is working. This can also be a defrost system proplem such as a timer and well worth fixing.
Jun 23, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Oct 16, 2007 | Amana 19.7 cu. ft. / 558 liter Upright...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Hoover HNU271AFFAL
as an ex hoover eng. these so called frost free units were never frost free!!!! if the unit was over gased in the factory it will over freeze. some early units were fitted with faulty modules and sensors. which were recalled thru engineer van stock but not to the public. call the service there service dept. but be careful not all hoover/candy/gias engineers are trained in refrigeration ( ask for a senior engineer. the staff turn over is huge!
Aug 13, 2007 | Hoover 9.9 cu. ft. / 280 liter Upright...
Refrigerators Logo
766 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
